Painting a trailer
AveryD12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Topic: Painting a trailer
    Posted: 08 Nov 2025 at 10:24am
I have an old trailer that needs a fresh coat of paint. It has numerous rust areas. Rust areas are not very heavy just enough to know the paint is gone. The trailer is yellow and I would like to repaint it black. Should I prime just rust areas or apply primer to the entire trailer? I will wire brush the rust areas. Other than pressure washing what should I do to the areas that still have paint?
Thanks
Avery
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2025 at 11:03am
Will have to clear any loose paint, and scuff the surface of the rest or will not stick for long..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2025 at 12:54pm
use a palm sander with 120 grit paper to scuff everything up.(after wire brushing the rusts)... I like the Rustoleum Red Oxide Primer for rusted spots... Also a good primer for the old paint areas.. You dont have to put a thick coat on, just enough to  cover and let it BOND to the old paint.. Let it dry for 24 hours, then any type of enamel paint for a top coat.
Edited by steve(ill) - 08 Nov 2025 at 12:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2025 at 9:41pm
Thanks. Had not thought about a palm sander but had considered an angle grinder with a wire wheel on the painted area. A palm sander would probably be safer as that wire wheel will kick back sometimes. Just wasn’t sure if sanding/brushing was necessary. I like the rust-o-leum red oxide primer for rusty metal just wasn’t sure if it would be good to use on the areas that still had paint or if I needed to use something else. Thanks again for the help.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2025 at 10:35pm
They have angle grinder sanding discs.
They leave a very nice bare finish, very handy cleaning up stick weld splatter and rust pits.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2025 at 6:10am
I first use a needle scaler to remove anything loose, then sand it. I blow it off with compressed air and wipe it down with Preps-all. Then I use Rust Reformer | Rust-Oleum over any spots with visible rust. Let the Rust Reformer (or Rust-Converter) dry, prime with a primer that is compatible with the paint I am going to use. Lightly sand again, blow it off, another wipe down with Preps-all and paint. I lightly sand, blow and wipe between paint coats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2025 at 6:57am
Thanks everyone for the great tips!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 5:59pm
Hope the picture loads.
Thought you might want to see the finished paint job. Not great but a lot better.
Thanks for all the advice
Avery
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 6:21pm
looking good... worth the time it took to do the job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 9:17pm
Looks like a new one!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 6:11am
yessh... I was thinking 4by8 'trailer', WOW that thing is HUGE !!! and PRETTY !!
Can it can a 'B' though !??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 7:45am
Thanks everyone. I have owned it about 12 years. Bought it with the intention of doing “this”. Just now getting around to it. I might tend to procrastinate a little 😂. New paint, new lights, new reflective tape & new safety chains. Deck is only a few years old. Should be good for several more years now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 3:22pm
One thing I have learned over the years is the 3M Diamond Grade tape is the only thing I have any luck lasting over a couple years. It is pricey, but in my opinion, it's well worth it.
