Painting a trailer |
AveryD12
Joined: 05 Mar 2018 Location: Foxworth.MS Points: 152 |
Topic: Painting a trailerPosted: 19 hours 11 minutes ago at 10:24am |
I have an old trailer that needs a fresh coat of paint. It has numerous rust areas. Rust areas are not very heavy just enough to know the paint is gone. The trailer is yellow and I would like to repaint it black. Should I prime just rust areas or apply primer to the entire trailer? I will wire brush the rust areas. Other than pressure washing what should I do to the areas that still have paint?
Thanks Avery |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34450 |
Posted: 18 hours 32 minutes ago at 11:03am |
Will have to clear any loose paint, and scuff the surface of the rest or will not stick for long..
Joined: 11 Sep 2009 Location: illinois Points: 88632 |
Posted: 16 hours 41 minutes ago at 12:54pm |
use a palm sander with 120 grit paper to scuff everything up.(after wire brushing the rusts)... I like the Rustoleum Red Oxide Primer for rusted spots... Also a good primer for the old paint areas.. You dont have to put a thick coat on, just enough to cover and let it BOND to the old paint.. Let it dry for 24 hours, then any type of enamel paint for a top coat.
Edited by steve(ill) - 16 hours 41 minutes ago at 12:54pm |
AveryD12
Posted: 7 hours 54 minutes ago at 9:41pm |
Thanks. Had not thought about a palm sander but had considered an angle grinder with a wire wheel on the painted area. A palm sander would probably be safer as that wire wheel will kick back sometimes. Just wasn’t sure if sanding/brushing was necessary. I like the rust-o-leum red oxide primer for rusty metal just wasn’t sure if it would be good to use on the areas that still had paint or if I needed to use something else. Thanks again for the help.
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1127 |
Posted: 6 hours 60 minutes ago at 10:35pm |
They have angle grinder sanding discs.
They leave a very nice bare finish, very handy cleaning up stick weld splatter and rust pits. |
