Painting a trailer
AveryD12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Topic: Painting a trailer
    Posted: 2 hours 49 minutes ago at 10:24am
I have an old trailer that needs a fresh coat of paint. It has numerous rust areas. Rust areas are not very heavy just enough to know the paint is gone. The trailer is yellow and I would like to repaint it black. Should I prime just rust areas or apply primer to the entire trailer? I will wire brush the rust areas. Other than pressure washing what should I do to the areas that still have paint?
Thanks
Avery
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 10 minutes ago at 11:03am
Will have to clear any loose paint, and scuff the surface of the rest or will not stick for long..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 minutes ago at 12:54pm
use a palm sander with 120 grit paper to scuff everything up.(after wire brushing the rusts)... I like the Rustoleum Red Oxide Primer for rusted spots... Also a good primer for the old paint areas.. You dont have to put a thick coat on, just enough to  cover and let it BOND to the old paint.. Let it dry for 24 hours, then any type of enamel paint for a top coat.
Edited by steve(ill) - 19 minutes ago at 12:54pm
