Paint Spray Gun Questions |
Dale (Stonelick)
Joined: 13 Jun 2019 Location: Stonelick, Ohio Points: 186 |
Topic: Paint Spray Gun QuestionsPosted: 10 Sep 2025 at 5:44pm |
My first time trying to paint with a HVLP spray gun and have a few questions:
Using an ancient large stationary Peerless 1.5hp air compressor located in my tractor barn (plate does not disclose CFM). I’m using a AllTrade Trades Pro HVLP gravity feed spray gun & cup with following specs on the large gun: Fluid Tip Dia 1.4mm, Air Consumption 11-13 CFM, Pressure 30-43 psi, Cup 34oz. Thanks in advance for any help - Dale |
1951 CA - 1944 C - 1949 B - Kubota M6800
Dirt Farmer
Silver Level Access
Posted: 10 Sep 2025 at 6:47pm |
Don't know about the paint amount needed or if you will have enough air capacity, you didn't mention how big the tank is. I an addressing the inline filter, attach it as close to the gun as possible cause moisture is the enemy in painting and all can look great then all of a sudden there is a drip of water mixed in the paint and not much you can do with that spot at that moment. Put the filter between the gun pressure regulator and the hose connector. Practice and patience, put some thinner in the gun and try spraying that on cardboard to see if the air keeps up and look at the pattern the gun is spraying. Seek out a couple you tube videos to get an idea. Good luck and wear a face mask to protect your lungs
plummerscarin
Posted: 10 Sep 2025 at 8:35pm |
The time between coats is called flash time. If using hardener, read the label to find out what working life is. At that temperature your working life may be much less than 40 minutes. Too much time between coats may have adhesion problems. Do not let that hardener set up in the gun or you'll be buying a new gun. Use thinner that is preferably same brand as your paint. As for hardener in top coat only? IDK, never tried that
jvin248
Posted: 11 Sep 2025 at 6:53pm |
Make sure to use a top face mask filter system. That epoxy paint gets in your lungs it hardens there. Don't screw around with that stuff. . |
acken
Joined: 02 Jan 2014 Location: Minnesota Points: 111 |
Posted: 11 Sep 2025 at 8:10pm |
I wouldn't risk only adding hardener to the final coat. The first coat is going to take longer to cure than the final coat.
I would also suggest the regulator be at the spray gun. If it is 50' away you might be surprised how much the pressure drop is at the gun. Using any ingredients that are not from the same manufacturer may not be compatible, if in doubt I always do a test panel, and let it set for a couple of days. |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5180 |
Posted: 13 Sep 2025 at 4:11pm |
I know painting is not a cheap or easy job. The prep work is by far the most work. I, personally, wouldn't take a chance on skipping the hardener on the first coats.
Dale (Stonelick)
Posted: 14 Sep 2025 at 9:55pm |
Thanks for all the advice. I got the tractor spray painted with 3 coats. Day one: painted the base tractor. Day two: paint the wheels, sheet metal and parts. Time will tell if it holds up for the long term. Some notes:
Now, to get it re-assembled and running. Thanks - Dale |
