Paint remover,,,??
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Paint remover,,,??
    Posted: 25 Jul 2020 at 5:15am
 A couple of weeks ago,, I cobbed onto an Edelbrock aluminum intake manifold for Big Brutus and have finally got around to puttin more assembly time on the new engine for Black Beauty. I had not noticed but the PO had painted the friggin manifold a grey color and musta put several coats of paint on a perfectly good aluminum manifold,,,!!! I got most of it off with my batter powered drill and a wire brush but cannot get into the nooks and crannies,,,,I tried some paint remover but did not even touch the paint,,!! Tried some more and left it on there for an hour but still no dice,,,paint never even got soft.
 Anybody got any ideas,,??
 OH,,,and NO TANNERITE,,Shameless,,,,!!!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 5:28am
seems to me brake fluid attacks paint.....at least on my 67 stang it did.....
one of the good paint strippers used in woodworking,the pasty types...
be super careful rinsing it of course..caustic chemicals and eyeballs is a bad combo...
big issue is WHAT type of paint and how old ?
you do need something 'aluminum friendly'....
maybe google 'removing paint from aluminum' ?
In the good old days I used CIL high speed automotive paint stripper, Used 2 gallons, yes real Cdn gallons to totally strip off 7 layers of paint off the 57 Willys pickup. top 2 caots were house paint....
sigh... wish I had that truck now...sniff,sniff...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 5:44am
Joe,
 Aircraft paint stripper is pretty good. NAPA should have it.
Edited by Sugarmaker - 25 Jul 2020 at 5:12pm
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 6:42am
Be careful with chemical reactions to aluminum. Since you sanded most of it off already you might try small sanding rolls for die grinders like those used for porting and polishing. While your at it you could port match the intake to the heads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 8:31am
Might should rethink the removal of the 'Sealant', later manifolds are already painted to seal the porous aluminum to stop the very metal from seeping vacuum.  We started seeing this issue with Throttle bodies on TBI cars mid 90s that got aggressively cleaned and removed the porosity sealants on them, got to checking back with our engine aftermarket suppliers where many 'Anodized' the parts to keep thru wall leaks under control, it is also noted that aluminum carburetors that  had been overly aggressively tanked do that same thing as the vacuum leaks over ride the idle adjustment capabilities.  They are currently Vacuum Impregnating aluminum castings at the factories where some are just applying sealing materials to the outsides.
Point of note on older cars and trucks with slow leak tires that seemingly cannot be located to repair yet requiring often refills, the rims were sealed at the factory, time, tire changes scuffing, abrasion, corrosion all affect that sealant coating and the darned wheels are the actual leak path.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 7:37pm
nay-palm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 7:39pm
as Jay says...brake fluid should do it...if not...spray sum aluminum paint over it, or sand blast them!
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 8:16pm
Brake clean /carb cleaner
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 9:20pm
Bead blast NOT sand blast, it's probably ceramic engine paint i.e. baked on tough as nails. When you get it cleaned down to the bare metal spray it with hi temp engine clear to seal the pores.
Edited by Bill_MN - 25 Jul 2020 at 9:21pm
weiner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weiner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 8:30pm
DMiller,  yes my wife experienced that very thing on aluminum wheels on a 2010 Toyota.  After fighting it for 3-4 years we went to steel wheels.  Not as purdy,  but no more hassel.
Real heros wear dogtags, not capes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2020 at 8:08pm
Sam Ting.......2007 Buick Lucerne.  ALL Buicks in those years had real problems and never a recall.  I won't EVER buy another Buick,,,,,,,,and not just for that reason.
This page was generated in 0.077 seconds.
