paint/primer questions |
Post Reply |
J&J
Bronze Level Joined: 24 Apr 2021 Location: IN Points: 15 |
Posted: 24 Jul 2021 at 10:50am |
I'm tearing down a CA for restoration. Will be using airplane stripper on the sheet metal.
The metal may sit for a while until body work/paint, so I want to shoot primer on it right away. I can paint, but don't have much technical knowledge of the process. What type of primer/sealer should I use? I don't know what type of paint I will use as of yet, so will some rattle can primer (eg. rust-oleum) be fine just to cover the metal initially? suggestions on primer and paint appreciated should stripper be used on porous metal? the cast iron parts? Thanks |
mdm1
Orange Level Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2591 |
Maybe just leave it for now. Since you don't know what you are going to use for finish paint. Primer needs to be compatible with the paint in some cases.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77234 |
i spray or brush RED OXIDE Rustoleum primer on the parts as i clean them-- for storage.
these parts were all painted by brush... then assembled. No need to disassemble to finish spray paint.. primers is in between the bolted faces. Edited by steve(ill) - 24 Jul 2021 at 1:00pm |
i normally spray the cast parts after assembly.. and the sheet metal parts seperate. Like to use acrylic enamel with hardener... It likes the red oxide enamel primer.
Play Farmer
Orange Level Joined: 13 Jan 2016 Location: NNY Points: 732 |
I'm a BIG fan of the self etching primers. I use that as a base then work off of that.
You can buy it in a rattle can and it's about as easy to use as anything you've ever sprayed. Be sure to use a mask though, it's nasty stuff - in a good way. |
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4605 |
I second the etching primer, it makes a good base and seals the metal.
Steve g
Bronze Level Joined: 17 Jun 2017 Location: Cen.ohio Points: 101 |
Years ago WD 45 rims I spent countless hours on them cleaning sandblasting painting Took them to a tire guy to have my tires mounted on them rims they looked good one hour up to his shop and one hour back to the house in a rainstorm. When I got back to the house the rims were already starting to rust through the paint not good. I used rust-oleum primer so I called rust-oleum tech support the bottom line was use rusty metal primer. So I did use their rusty metal primer and it worked fine from now on any parts that I do will get rust oleum rusty metal primer first coat
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7935 |
Id luv to see the way Allis painted - bet those guys in the paint booth were busy ! What was the process then ? Alot of mine have a yellow primer , then the finished product is great
Edited by DougG - 26 Jul 2021 at 6:02pm |
AC720Man
Lead paint was good stuff, nothing comes close to it today. I still recommend etching primer, has been good to me after 8 years.
Post Reply | |
