paint off of old tractor rims
Roundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Topic: paint off of old tractor rims
    Posted: 26 Jan 2020 at 5:40pm
Is there any easy cheap way to remove paint off old tractor rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 5:56pm
Several things come to mind.
Sandblasting may be the best. it may cost you up to $100 for a pair. I like to have the tires removed and then blast. It can show if the rim has any weak areas too.
I got a pair done for $50.00 a few weeks ago.
Electrolysis process is very low cost but the set up to have  a tank that big may be prohibitive.
Mechanical wire brushing can work too.
Also paint removers can loosen a lot of old paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 6:21pm
A lot of shops have switched to Soda Blasting to get away from Silica Poisoning issues, we used Black Magic agent which was basically Coal Cinders, not a lot of call nor people to do this around here anymore.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 7:16pm
I had a pair blasted with centers and the eccentrics all included.  I had them all disassembled so they had lots of small stuff to do. They were doing big dump trucks and the rear axle area of road tractors.  Couple years ago now, it cost $150 if I remember correctly.  I was very pleased with the job.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2020 at 7:40am
If you have an old stock tank, Line it with 6 mil plastic sheeting.  Fill with your electrolysis solution.  Put a plastic grid in the bottom to hold the rim off the bottom.  Hook up the wires and such.
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2020 at 10:36am
I have used A1 Paint Powder  & Sandblasting in KC with great results
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2020 at 2:23pm
'blasting' is faster but $$$ compared to electrolsys, depends on what you value  time or money.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2020 at 4:11pm
Burn them off! --- Watch how long you leave them in the fire. I saw a guy do this one time, after the burn he wire brushed them, then washed them good. Didn't seam to hurt the rims any.
I use a big body grinder to clean them. There is no easy way to do it and any way is going to cost money.
