? Paint color
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Topic: ? Paint color
    Posted: 17 Mar 2021 at 7:33am
What color were the rear centers, wheels and front wheels on the 7060
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2021 at 8:27am
Persian Orange Paint
From AGCO Persian Orange #1
In the Quart Can #79014785 ---- $60 (in Canada November 2012)
In the Spray Can #79014664 ---- $14 (in Canada November 2012)
They don't sell gallons.
From AGCO Persian Orange #2
Manuf                    Paint Color                                 Ditzler        Dupont      NAPA            Martin Seynor    Tisco
                            Name                                         PPG
Persian #1
Allis Chalmers        Persian Orange                             60080                         3723L99        90R-3723        TP280
Persian #2
Allis Chalmers        Persian Orange                             60396        29047
Allis Chalmers        Tractor & Equipment Orange    60856
Page From PPG Paints
Allis Chalmers Cream---------------------------------    8638
Allis Chalmers Cream (Beige) - Trim Color-----------    23056
Allis Chalmers Earth Removing Equipment Yellow----    81233
Allis Chalmers Earth Removing Equipment Yellow----    81611
Allis Chalmers Earth Removing Equipment Yellow----    81985
Allis Chalmers Lift Truck Yellow-----------------------    81475
Allis Chalmers Persian Orange (Persian #1, so called)- 60080
Allis Chalmers Persian Orange (Persian #2, so called)- 60396
Allis Chalmers Orange--------------------------------    60691
Allis Chalmers Tractor & Equipment Orange----------    60856
Allis Chalmers Yellow----------------------------------   81330
Allis Chalmers Yellow---------------------------------    81960
Allis Chalmers Yellow---------------------------------    82373
Allis Chalmers Yellow----------------------------------    82630
Allis Chalmers Black-----------------------------------    9000
Allis Chalmers Black-----------------------------------    9300
I think there is a #1820 Krylon for Persion Orange 1.
Allis Chalmers Early Persian Orange
PPG Formula For OMNI Acrylic Urethane (MTK60080) (NO LONGER SOLD)
Single Stage Color
Qty: 1 Quart
Code        Color                      Cumulative        Parts
M117        Jet Black                    15.4              15.4
M120        Tinting                        35.2              19.8
M115        Yellow O                   173.5            138.3
M114        Light Ch                    326.6            153.1
M130        Orange                     514.6            188.0
M195        Accelera                    533.8              19.2
M149        Mixing C                  1150.0            616.7
PPG Formula For Deltron "Concept" Acrylic Urethane (DCC60080)
Single Stage Color
Qty: 1 Quart
PPG Color Library
Color: Orange MSDS: DCC2        VOC: 4.11        Lead: 15.98%
DMC90        Strong White                                        35.4               35.4
DMC90        Yellow Shade Moly Orange                 1127.7            1092.3
DMC90        Medium Chrome Yellow                     1489.6            361.9
DMC90        Carbon Black                                    1523.9            34.3
I like PPG Delastr Acrylic enamel 60080, perfect PO1 match, great paint.
PPG Automotive Finishes
Tractor and Implement Colors
        Caution: This list was assembled using three different PPG sources plus input from others. There was no information concerning model or year, except as noted. Use this list at your own risk. There are no guarantees. I have only confirmed the AC early persian orange, sometimes referred to as "persian #1", as 60080. Most of the codes should be available in most, if not all, current PPG automotive paint chemistries, including the economy OMNI line. See your local PPG jobber for details. I strongly suggest first purchasing the smallest possible quantity in an attempt to verify the proper shade. Custom mixed colors are not returnable. Unfortunately, whenever a color proper name has multiple codes listed against it, I have no idea which one is appropriate for your application. If you are particular about shade, you may have to sample them all. If you wish to get information on the different chemistries available from PPG, including technical data sheets (detailed usage info) and material safety data sheets (MSDS=safety & health info), go to the PPG website. http://www.ppg.com/cr-refinish/phase1/frmHome.asp
        Allis Chalmers Cream------------------------------------    8638
        Allis Chalmers Cream (Beige) - Trim Color--------------    23056
        Allis Chalmers Earth Removing Equipment Yellow------    81233
        Allis Chalmers Earth Removing Equipment Yellow------    81611
        Allis Chalmers Earth Removing Equipment Yellow------    81985
        Allis Chalmers Lift Truck Yellow-------------------------     81475
        Allis Chalmers Persian Orange (Persian #1, so called)--    60080
        Allis Chalmers Persian Orange (Persian #2, so called)--    60396
        Allis Chalmers Orange-----------------------------------    60691
        Allis Chalmers Tractor & Equipment Orange-------------    60856
        Allis Chalmers Yellow-------------------------------------    81330
        Allis Chalmers Yellow-------------------------------------    81960
        Allis Chalmers Yellow-------------------------------------    82373
        Allis Chalmers Yellow-------------------------------------    82630
        Allis Chalmers Black---------------------------------------   9000
        Allis Chalmers Black---------------------------------------- 9300
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2021 at 8:44am
Maroon chassis gets cream wheels. Black chassis gets cloud white wheels.
This page was generated in 0.465 seconds.
