P3100 on a One Eighty ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: P3100 on a One Eighty ?
    Posted: 31 Dec 2020 at 4:35pm
Got a One Eighty 301 engine with a Bosch A pump on it - curious- will a  P3100 bolt onto the adapter plate for the A pump? Its the 301 diesel block with cam driven oil pump Thanks !
Edited by DougG - 31 Dec 2020 at 4:40pm
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 10:30am
No the hub size is different. And bolt pattern is bigger. Have to grind the pump and block to make it fit. Also we add a bracket to the back of the pump to support it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 11:42am
Thanks for the info , but it is do-able then? I have a few front engine plates here- next question will be will the stock front gear cover fit ?
Edited by DougG - 01 Jan 2021 at 11:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 4:36pm
The OD of the gear is the same as the original
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 3:36pm
Ok thanks
