overhall kit
lost in h3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Topic: overhall kit
    Posted: 06 May 2023 at 1:22pm
My dozer is an h3 serial number h-1451-r.  I ordered overhall kit and the kit is to small. My cylinders without sleaves measure 3 7/8" not the standard 3 1/2 ".
I don't see a kit with this measurement listed anywhere. What do i have?
Help please.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 2:11pm
Later H3 had the G160 engine with bore 3.625
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 4:13pm
similar to the D15 series II farm tractor.........
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 4:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2023 at 9:59pm
Its looks like I got lucky and have the more expensive engine. I'm not good at decimals so I'll call my supplier tomorrow with the bad news. I hope they take the kit back that won't work.
Thank you for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 7:26am
G-160 engines have a one inch diameter "floating" piston pin with a bronze bushing in the connecting rods. The G-149 engines have a .990" diameter clamped piston pin in the connecting rod end. The G-160 bore is 3 5/8" not 3 7/8".
This page was generated in 0.324 seconds.
