Outside storage question |
Hubnut
Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |
Topic: Outside storage questionPosted: 20 Nov 2016 at 12:43pm |
I have a storage problem and will need to move a tractor or two to my pole barn. These are restored tractors. Any ideas on how to best keep them in a pole barn and getting infested with critters or rusting from exposure?
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia" 1942 B w/ finish mower "Dick" 1941 C w/ 3-point "Maggie" 1947 C SFW w/ L306 "Trixie" 1972 314H |
WDman1951
Joined: 18 Jul 2015 Location: Fargo ND Points: 1208 |
Posted: 20 Nov 2016 at 12:50pm |
I keep mine on my trailer under tarp its not fully restored but I have yet to see it get any worse than it was and seems to keep the elements off it for the most part. Just put a glove over the stack so it doesn't rip your tarp up alot. Works best if your bungee cord the holes on to the tractor so the wind doesn't take it
1951 WD 1945 C 1936 WC
Posted: 20 Nov 2016 at 1:00pm |
Any type of tarp or cover, even if tied securely, will rub on the paint and scuff it in places, if the wind has the ability get at the tractor.
Dakota Dave
Posted: 21 Nov 2016 at 7:56am |
A tarp also retains condensation and promotes rust. Just make sure the tool boxes and other areas are free of any kind of materials and put traps nearby. If you don't have flappers on the exhaust put a can on it even if parked in the pole barn. A good coat of wax on clean paint will keep bird dropings from damaging it, and it'll be easier to lean when you take it back out.
Butch(OH)
Posted: 21 Nov 2016 at 8:13am |
When we moved over the last year I had to store some of my restored treasures in less than perfect conditions and I learned a bit. As Doc said dont cover them, dirt and poop washes off, tarp damage does not and tarps hold moisture in. Just let them get dusty and dirty and wash it off when you can put them back in good storage. Dont wash the tractor spray some type of oil on any shiny metal that you don't want to rust. Leave the tool box open and mice will not nest there. Do cover up the clutch and brake housing inspection holes.
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 21 Nov 2016 at 8:24am |
As I've put on here before, put plastic under the tractor, not over it. Moisture travels up and then down and it seems to me that anything parked over ground or concrete will wick up the moisture, so block it off with the plastic. X2 on the dust, wax and other suggestions.
Dakota Dave
Posted: 21 Nov 2016 at 9:27am |
I had 100 yards of gravel hauled in and leveled it off. A little slope in each direction so I now have a well drained gravel parking spot for every thing that sits outside. Any time you park over grass your parking on top of a moisture pump. As the grass or weeds in my case grow they wick water up. Plants have to have water to create energy. When they touch metal invariably some sap is transferred to the metal just by the wiping action when the wind blows. Sap is a slightly sugary water solution and it causes rust. If you have to park over grass move it every couple weeks and mow it short.
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 21 Nov 2016 at 9:40am |
If you want to cover it to keep anything like bird droppings off it then use a cotton/fabric cover.
1957 WD45 dad's first AC
Brian Jasper co. Ia
Posted: 21 Nov 2016 at 12:49pm |
In any places mice would want to nest throw some moth balls
WDman1951
Posted: 21 Nov 2016 at 3:45pm |
Ah oh I've been doing it wrong this whole time I always heard without a tarp it cover you'll get weather cheeked tires, sunglasses paint animals and all sorts of awful stuff guess I don't have to buy anymore tarps then lol
Hubnut
Posted: 21 Nov 2016 at 5:53pm |
Thank you all for these suggestions. I never thought about putting a vapor barrier under the tractor, but it makes sense.
1940 B "Lucy"
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54670 |
Posted: 21 Nov 2016 at 6:01pm |
Cover it up with straw bales, and cover them with the tarp. Then all you has to worry about is mouse nests...
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 21 Nov 2016 at 7:04pm |
you can hang a tarp up on the bottom side of the rafters, letting the sides hang down about 2 ft all around. that will keep some of the bird poop off as they will sit on the rafters and the tarp will catch that part, and the waving and fluttering of the tarp edges will keep most of them from landing on the tractor to poop!
