ot !! woods hd 315
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Topic: ot !! woods hd 315
    Posted: 16 Aug 2012 at 5:23pm
im using my neighbors batwing mower and the shaft on the wing (right side) pulled out of other shaft  and i found a broken 3/8 roll pin.  i got a new pin but cant find out where it was put together at, there is a spring on outside of gearbox and the two shafts slide together and im guessing the roll pin holds the shaft from sliding out ? butwhere does roll pin go ???
                                 Shawn
190XT,D17and 7045
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2012 at 2:00pm
If you're talking about the square shaft that slides all the way through the wing gearbox, it will go through the square shaft just before the end.  It should have a roll pin-washer-spring on the outside of the gearbox (side closest to the wing edge).  It may be a spirol pin, I can't remember since we got rid of our b320 a few years ago.  Generally this is caused by long shaft (the actual PTO shaft between the wing gear box and the center box) being rusty inside and not sliding smoothly when lowering the wings.
Here's a good picture of one:
Hurst
1979 Allis Chalmers 7000
5800 Hours
