OT Richie Cattle Waterer
Rod5300 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod5300 Quote  Post ReplyReply Direct Link To This Post Topic: OT Richie Cattle Waterer
    Posted: 09 Jan 2018 at 3:10pm
Hello, I am wondering if some of the fine Allis folks that have these fountains had problems with them thur the last 10 days with below normal cold temps. Had a couple that froze, but not much problem.
Also any tips or advise for helping to keep these fountains from freezing etc.
One tip I will pass along is that for unthawing mine I use a piece of flexible dryer vent pipe, put it over my exhaust pipe on truck and put the vent tube inside the fountain, cover the lid opening with feed bags and get inside a warm truck and let it thaw. Usually about 10 mins   works well.
Thanks so much for looking and commenting on this post.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 3:51pm
I guess the combustion products of the vehicle exhaust doesn't contaminate the water.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 4:05pm
Not enough to worry about
Wink
I am a Russian Bot
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 5:05pm
I have a one that uses electric and you NEVER have to worry about it. I also have a MiraFount that uses ground heat and only problem with it is the floating balls will freeze around the top where they seal. I go to dollar store and buy cheap jar of Vaseline smear a heavy coat of it around the lip where the balls seal. After doing this about 3 days in a row entire ball will be coated with it and if the balls do freeze it won't be much and one hit with your hand will free it. If I had it to do over I would have buried electric wire and bought another ritchey that used electric.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 5:15pm
I haven’t had any trouble but mine are electric. I bought a Richie combination waterer in 1988 and replaced it last year. Had to get a cattle waterer because he said they didn’t make a combo any more. New one is plastic the old one was medal
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 6:25pm
I asked my wife what unthawing is. She said freezing.
Dusty
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 6:33pm
I have a couple of them. Electricity going to both of them. One has a stainless steel trough, and it has a couple heating elements attached to the underside of it. Other one is all plastic, and has a sinking heating element in the water basin. I have a light bulb socket wired into the inside of both of them, and so usually about a 60 watt bulb burning in them keeps the plumbing from freezing up. If the bulb burns out and it happens to freeze up, putting a heat lamp bulb in thaws stuff out pretty fast. Do NOT forget to remove the heat lamp bulb after things warm up. Don't ask me how I know that. Darrel
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:01pm
Like Darrel said, I had a light bulb under mine, it dried things out under there and didn't freeze as easily
ldogfarm View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote ldogfarm Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 1:32am
I have 11 of the freeze-proof and every year they give more trouble with freezing overflowing plugs coming out and whatever.
They are fine fore the first couple years then they start giving trouble. Parts are off the chart expensive. Plugs $20.00+ floats around $30.00 valves $18.50 float balls $36.00.
General top parts the break down from UV rays unavailble.
I would not recommend them to anyone.
For me most of them freeze if it gets in the teens and don't reach 40s in the day.
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 9:39am
It's 28 below c here this morning and we have a few months of cold yet just like every winter.
  With 200 sheep to keep watered plus an assortment of bovines and horses you become an expert on waterers. I have 1 ancient Ritchie(25 years old).
   Make sure thermostat is functioning and element is not burned out.Most of our problems with waterers happen below the box in the hole that the water  line comes up. The frost here penetrates to 6 or 7 feet so our water lines are buried 8 feet deep or more and the standpipe will freeze for the first couple of feet below ground level. To counter that most are wrapped with a heat tape from top to bottom. Make sure to situate the thermostat at the frost level or it won't turn on!
   Last point is make sure you have animals using it. The more the better.The moving water will keep it working.Bail a few bowls full morning and night if you need to.It helps a lot.
   Good luck.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 9:47am
We just put a new one in in November.  Sure seems chincy made for the price, but at -13F last week it didn't freeze.  Has a heating element under the pan, and a heat tape that traces the water line downward.
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 10:28am
All of the above recommendations are good. One that isn't mentioned and is, in my opinion, most basic is to place a 4-6" PVC pipe around the water pipe feed at least one foot below frost line. I even had six waters not installed this way I corrected one summer. Well worth the effort!
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 4:32pm
  Howdy,
Had two Richies, first one was metal second one plastic. Both were great, but in the wind had to put piece of plywood on side of wind other wise, freeze over.  Horses ate the plastic one! How about that?
Kurzy
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 6:25pm
Have Ritchie waters with electric elements. 22 below here new years day. No problems.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 11:13pm
We have had the same Ritchie waterer since the early 1970's.
 Great unit.  Have had to replace the thermostat a couple times.  Other than that, no problems.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 3:36am
Hey Darrel, do you think you could wire one of those to your arse so it doesn't freeze off while you're out spreading hay or starting the little womans car? Just wondering.LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 6:36am
I doubt it. Those elements get hot, and I'm not Keene on the idea of a horse shoe brand on my back side. Darrel
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 8:14am
I can't tell from your post if you used the earth tubes or not, or if you ran electricity to it.  I am guessing you didn't run electricity if you used the exhaust pipe.  In KY, you might not need electricity in most years, if you have enough animals drinking out of it, unlike the extreme north.  I use the earth tubes that are about 12 inches in diameter and lets 55 degree air float up and keep the lines and the interior of the waterer somewhat warm.  However, I have had the float freeze to the top side of the waterer when it gets below 0, like the past week.  When the float freezes, the water in the tank doesn't, then the animals drink it down, which lets air into the valve and freezes it.
When I install my waterer concrete pad, I run a 2 outlet plug in conduit in the inside.  This way I can plug in the water tank heater and a 60-75 watt bulb.  That bulb will keep the lines and the float from freezing in about any coldness as mentioned above.
If the float and or the valve freezes, I remove the top, plug in a hair dryer and cover it with plastic and let it run about 30 minutes.  This won't melt the waterer or valves since it is plastic, but still gets it pretty hot.  Of course, you have to secure the hair dryer with a bunge cord to prevent it from dropping into the water when it thaws.
In Kentucky, most years you would not run into this problem, but this past week was rough.  If you didn't use the earth tubes then I recommend it.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 8:24am
Dusty
YEPThumbs Up
Edited by JoeO(CMO) - 11 Jan 2018 at 8:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod5300 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 4:09pm
Ky Allis, I tried your tip and it worked like a charm With all the freezing rain etc we had yesterday I went to check cattle this morning and stopped at the fountains and took my hand and moved the balls around   All my fountains will get coated with vaseoline   Thanks again for the tip
Rod
This page was generated in 2.969 seconds.
