OT Oliver Problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Topic: OT Oliver Problem
    Posted: 02 Sep 2010 at 12:39pm
I know this is the wrong color but yesterday I went to start the old Oliver and drive it around a little and when I pulled the lever that turns the power on everything worked as it should. Then when I went to push the starter button it didn't do anything. On top of that the button got really hot really quick. What is wrong here.
Too bad I don't have the hand crank or I could crank start it and forget the starter and button thing for now.
Sorry for the off color question. Jeremy
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 5:41pm
If you've got an Oliver then you HAVE a problem! LOL
Did you check to see the wires are tight on the switch? Starter stuck in gear?
Wink
I am a Russian Bot
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 5:47pm
 Sounds like the switch is grounding out if it is getting hot.
Edited by split51 - 02 Sep 2010 at 5:48pm
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 6:00pm
Start tracing it back . Is the switch the type that operates a solonoid , if so then disconect the wire from button and check that with meeter or bulb, if OK then check solonoid or starter itself.
 If Delco type starter weth solonoid it has 2 sets of windings , pull in and hold in , which are controlled by the disc in cap of solonoid.  If it is drawing full voltage through button to ground solonoid you will have a problem.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2010 at 7:20am
Those push button switches tend to get problems.  The first thing I'd try is getting a new one of those.  I've fixed several of them by tearing them apart and making new insulation for the terminals.  It sounds like when you push in the button, you are probably grounding something in the switch.
This page was generated in 0.081 seconds.
