OT Fuel pressure, adjustable
Charles Craig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles Craig Quote  Post ReplyReply Direct Link To This Post Topic: OT Fuel pressure, adjustable
    Posted: 02 Feb 2010 at 4:31am
     Let me apoligize to the people on this forum because this is not AC but is tractor related. I have a "HOUGH" Payloader model 50.  the original fuel pump has been changed out. This machine has a IH engine ,like in a pick-up.  I talked to the PO and he admitted to the "change" .  My dillema is that I dont know what the correct fuel pressure is. Can any one enlighten me. All opinions will be greatly appreciated.  TIA    CC
AC BD3 roadgrader "D" road grader SIX "old" cars Farmall 300
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 4:37am
is it a gas engine? what kind of fuel pump? diaphragm or electric?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles Craig Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 4:49am
  GAS --MECHANICAL  Diaphram I think   CC
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 7:29am
The new fuel pumps get eat up by the new gas we have if they sit for a period of time. combine engine has had pump replace twice in 3 years.  The last pump taken off, you could blow ir through it backwards. Can't pump fuel that way.  Take pump off and stroke lever and hold thimb on discharge port, it should hold pressure until you release your thumb from port
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles Craig Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 3:51pm
  the mechanical fuel pump that is on the engine now is overloading the float-shut off in the carb.  What is the optimum PSI for this set-up/. I have an adjustable regulator that goes from 1 lb to 5 lbs.  Thanks in advance   CC
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 5:46pm
any info i have found says 4-10 psi. i would go on the low side if your float will not hold. if it still will not shut it off, replace the needle and seat. it does not take much pressure to keep a carb full, just volume. hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 7:25pm
Check and make sure you floats are not crushed or full of fuel, check to make sure your inlet to carb is absolutely clean as well as the needle seat area. Also check float height and make sure your float arms are not bent to the point that it allows flooding.
