Orange hydro hoses
clays37ac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clays37ac Quote  Post ReplyReply Direct Link To This Post Topic: Orange hydro hoses
    Posted: 09 Jan 2017 at 8:51pm
I'm getting ready to order orange hose to remake the factory type allis Chalmers hydraulic lines if anyone is interested in any
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 1:44pm
I did not know they were orange? I figured they were just painted after installation?
 Some pictures and pricing and lengths and fitting sizes  and for what tractors, might just get you some business??
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 5:48pm
I have only seen orange hydraulic lines on the 400 loader I had.  Never seen them on tractors (aside from the rigid steel ones).
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 5:52pm
I have a 9000 series plow with an orange hose on it.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 6:42pm
Disk, 2000 plows, field cultivator, 330 & 600 planters all had orange hoses. To my memory tractors never had orange hoses. Put a LOT of them together over the years.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 6:50pm
My 1300 field cult. had all orange on it! thanks; ac fleet
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 5:22pm
Could you give the size and specs (psi rating) of the hose, and price per foot? I'd be interested in some. Thank you.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 5:53pm
I might need some on my next project, already bought half the hoses for my disc. I'm just gonna coat them with a few coats of paint. It takes a lot of footage for a 2600. There was still a few originals on it with the orange rubber hose.
Edited by Daehler - 14 Jan 2017 at 8:26pm
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 5:59pm
My 1200 field cultivator had orange hoses, not painted
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote clays37ac Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 11:05pm
This hose I'm getting in is like the original it's actually orange
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 5:50am
My 1400 cultivator has orange hoses.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 6:29am
I was looking at some of those hoses on my disc think they say dayco daylon on them.
Definitely orange and they for sure don't like heat around them where the rubber hydraulic hoses will tolerate a little from a torch.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 7:05am
Does color matter? I know it does with coaxial cable. Orange indicates that it is plenum grade. Does it make any difference with hose? The color can indicate what type of gas or liquid the hose carries, I suppose.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 6:53pm
The Orange hose would most likely be thermoplastic hose. SAE 100R7 and 100R8 are for medium pressure hydraulics. A little higher cost per foot.
