opinon on an allis chalmers 8010
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: opinon on an allis chalmers 8010
    Posted: 01 Jul 2012 at 7:21pm
Just wondering how good the hydraulics,power director transmission, cab, pto, 301 engine, rear end etc. any info would be appreciated thanks
Edited by AC 426 power - 01 Jul 2012 at 7:24pm
MitchB View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MitchB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 8:15pm
I've owned an 8010 since new.  It has about 4500 hours on it & I think it's an all-around excellent tractor.  The only issue we had with the engine was from electrolysis eating a hole in one of the liners, but that's an issue with any wet sleeve engine.  Otherwise it's a good comfortable tractor to operate.  Good cab with high visibility.  We use ours mostly for tillage work.  The PTO worked fine on our chopper & haybine.  It's a bit under-powered for a powershift transmission, but the power director works well.  Mitch & Barb in West Michigan
Allis Chalmers WD, D14, D17, 190, 6060, 6070, 6080, 8010, I-600, I-615, R62
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 8:44pm
Electrolysis is only an issue if you don't look after the coolant. Test coolant with test strip at every service and add DCA as needed. Change coolant filter if you have one- they come with different levels of DCA. If you can't do that change coolant every 2 years and you will not have problems. Highway tractors can go million km on same coolant if maintained properly.
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 9:51pm
how about hydraulics in cold weather like zero and below  do they work well or are they slowed down ?/
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 9:55pm
Hydraulics work good in cold weather. They are a great tractor.  MACK
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 9:57pm
what hydraulics do work good below 0, til the oil gets warmed.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 10:39pm
Uncle has an 8010 FWA p.s.  Been a very good tractor for him.  Has around 11,000 hours on it now.  Been pretty well trouble free.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 1:42pm
We have two. One is a power shift 2wd and the other is power director fwa. Great tractors that are good one fuel. But I have always thought the little 301 wasnt quite enough engine for the big frame they are in. Our P.S tractor is currently for sale too.
Making a living farming with and working on Allis Equipment
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 9:08pm
We have a 8010 fwa ps.  Dad traded a 8030 fwa ps because he thought the 8010 would do the same jobs and use less fuel.  Found out that it uses the same amount of fuel and does not pull quite as good.  LOL...I think I mentioned that to him before...I since bought a 8030 2wd pd, it will easily out pull the 8010 and I would hasten to say it would give the 8030 fwa a run for all it was worth, the ps transmission makes them seem like a dog, the pd does not.  One thing is for sure, you do not need fluid nor weights on the 8010 for traction, the 8030 does.
Edited by Amos - 03 Jul 2012 at 9:08pm
