opinions on Howard rotavators? |
troy(el paso, il) ![]() Silver Level ![]() Joined: 28 Sep 2009 Points: 124 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Dec 2010 at 10:11am |
Hello All-
Just wanted to know people's opinions of Howard rotavators or comparable 3 pt. tillers.
Thanks......Troy
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
The old "Selecta-tilth" models are virtually indestructable....I bought this old guy 9 years ago and have gone thru 2 sets of tines and tons of rocks. This year alone it tilled almost 90 gardens. This 5 footer will make the 175D work at times, and the front end gets a little light when loading it on my trailer. I have a backup just like it sitting out back...as for the newer models, they just don't look like they are built nearly as heavy.
ALLIS EXPRESS!
This year: |
JohnCO ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
I ditto Eldon. I heard that they were bought by an Italian company and the quality dropped. I've got one line Eldons' and other then a pto cross going bad and tines wearing out, it's been a solid machine.
Allis Express participant |
Thats "one LIKE Eldons".
Tricky Dickie ![]() Silver Level ![]() Joined: 05 Nov 2009 Location: North Yorkshire Points: 186 |
I well remember the old Selectatilth Howards. My father used to grow a large acreage of potatoes and we had a 70" model at home when I was young. It was mounted on a Fordson Super Major and my father used to send the driver off to rotavate potato land with the excess fuel button wired in to give the tractor the extra power it needed to drive the rotavator at full depth. Super Majors had a high geared pto shaft (540 rpm @ 1200 engine rpm) so the tractor needed that bit extra - my father used to take an extra 10 gallons of diesel to the driver at about 2 o'clock each afternoon to keep him going until evening because of the rate the tractor was consuming it!. That roatavator was indestructable and was only replaced when bigger tractors came along and could handle a wider model - again a Howard!
Tricky Dickie
Rayhowling ![]() Silver Level ![]() ![]() Joined: 02 Jan 2010 Location: Ont. Points: 178 |
I have one like Eldon's, a 5 foot model. I have had it about 10 years and it was 10 years old when I bought it from a friend. I run it with my Allis CA, it makes the CA work but when I brake sod or grass ground I put a bigger tractor on it. They are one tough tiller and I hang a couple of suitcase weights on the front axle of the CA to keep the front end on the ground. I have a 8 foot model which needs some work done on it. The chain drive is broke and the tines are worn out. Are there any after market companies that make tines for these kind of tillers? I replaced the tines on the 5 foot model a few years after I bought it, but they are pricey.
KenBWisc ![]() Orange Level ![]() Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1183 |
They will make a field look like a garden. My father-in-law was a dealer and used one on 160 acres of corn ground and then planted it to soybeans. He ended up with succotash which ended it's use and the dealership.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Well....my Howard got a bellyache this morning. I tore the right side down, the bearing went out. Now I am not sure what I need to fix it. Fortunately the shaft where the bearing seats is ok, but the nut came off the end and the threads and it are shot. I'm thinking if I can find an outer labrinth seal (the big round steel flange), and whatever the other seal in there was, I can snug up the nut and put some weld on it to keep it tight. I might just try to find a sealed bearing to put in there. Now I am back to my backup machine, kinda scary! Anyone know where to find parts???
ALLIS EXPRESS!
This year: |
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2496 |
Ditto. I had a 6 footer for 25 years and ran it with a Case 970. They are indestructable!
Steve M C/IL ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
No one has mentioned the gear set in the drive box which lets you select tine speeds.Pretty cool units.
Eldon, there was a distributor in Ill I bought some parts from years ago. Unfortunately I can't find the name in my files. I suspect you can fix it with standard parts for a lot less $ and maybe a bit more work.
Rawleigh ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
Take the bearing to a bearing supply house and have them match it. It will be a lot cheaper and you can get the latest bearing technology. See what happens when you brag on a piece of equipment!! LOL! Sorry for your problem.
Yes I am going to try to find a sealed bearing for it. I think the end just bolts on to the shaft, so I will probably just put a sealed bearing on and weld the nut back in place. After that bearing goes, it will be time for a replacement end from a donor machine, or try to find a new one.
ALLIS EXPRESS!
This year: |
Or find a good machinist.
Good machinists are expensive around here....and hard to find. I do have a buddy with a couple of CNC machining centers who says my money is no good there....may make a nice winter project for him.
ALLIS EXPRESS!
This year: |
