Opinions needed..
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Topic: Opinions needed..
    Posted: 10 Nov 2014 at 7:19am
  I purchased a WC last Saturday. It's a long story but I made the drive to buy a WD or a WD45. One there it turned out to be a styled WC. The owner swears it was running two years ago. Very nice sheet metal, shutters on radiator, lift system, etc. Everythings there except for the shutter crank the engine hand crank, and lights. I bought it with intentions of maybe trading it for a 45. Looking to build a div.2 tractor for the wife and kids.
  But then again seems everyone wants a WC to pull with, so what do yall think? O yea, the engine block is cracked, right behind carb. I saw it dripping yesterday. Thats no issue with me if I build a puller, I have combine engines sitting everywhere.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2014 at 10:20am
WC's make good pullers.  Are a little lighter than the WD's.  Only real complaint is the hand brakes.  Mine has an aftermarket set of foot brakes on it that are nice, but not near the brakes as a WD has on it.    Easy to work on thats for sure.  6-9bolt adapters are easy to make also for 38's.  I swapped in a Speed Patrol rear end that is lower geared than the stock unit.  The RC rear can be used but some say not as strong as the WC rear end.  Also can find "picker" gears for it to slow it down. My second gear is about what first gear was with the stock rear end.
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2014 at 3:41pm
get some old f20 wheels. there the same six bolt. and can be or already have been cut down to 38 rims.
This page was generated in 0.168 seconds.
