Opinions about an HD11 on CL
Ferdinand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Topic: Opinions about an HD11 on CL
    Posted: 09 Sep 2017 at 8:37am
What do you guys think about this dozer? Is replacing the driveshaft a deal killer?
https://raleigh.craigslist.org/hvo/d/allison-chalmers-hd11-dozer/6257270810.html
Because narrow is the gate, and narrow is the way, which leads unto life, and few there be that find it.
Mathew 7:14
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 3:12pm
First it would have to run, there are parts machines out there for a shaft MinnPar may have components as I do not know why it would need an entire shaft. Has Rockwell bolt down u-joints so may be able to purchase thru a truck shop by dimensions.
As to the $4000, rails are shot, shoes are too where those are a non-available. Have toyed with installing Cat 6.906 rails on worn sprocket but if have bad rollers then the trucks will need come off for mod to another manufacturer.
Again it will need to start and run for $4000.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 9:39pm
Lots of good parts- should be work $4k- I just paid that for this one with a blown engine and bad undercarriage- still too good to scrap.Smile
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 11:06pm
Ok...I'll weigh in on this...normally a drive shaft would be a simple fix....butttt.... more than once we've seen these driveshafts destroy the torque converter shaft leading to torque converter removal and replacement of shaft....which are hard to find. It would be good if you could look at the tractor and check out the drive shaft. Then again maybe it's as simple as changing a u joint. If you only have one of these tractors and need all of those parts and some undercarriage too...it could be very expensive.
  Soooo...all that being said...I'm going to sign on with Trevor...if you had more than one of these tractors (he does...we have 4) I would pay $4000.00 in a heartbeat for this for a parts tractor...hope that doesn't confuse you to much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 11:19am
Thank you, gentlemen.  If I were to buy it, it would be my first dozer purchase. Nothing around here but, a couple of small farm tractors.
Maybe tackling a monster like this HD11 is a bit too much for me.
Mathew 7:14
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 3:45pm
If you could find another in the same price range that was running and working then buy this for parts.
Edited by DMiller - 10 Sep 2017 at 3:45pm
Josh H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 7:26pm
Hey, is that a 16b to the left of 11b? Should of uploaded that one!
One problem is getting it on and off a trailer
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2017 at 4:14am
looks like you got a good buy Trev
even came with a 'wench' for you !
Cheers Merv
tits tyres and tracks
they all cost you money
