Open station platform mat
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: Open station platform mat
    Posted: 03 Nov 2016 at 8:26pm
Does anyone have a picture of what the open station 7000 series used for the black mat on the floor? Was it glued on or riveted? Did it have a pattern to it? Did it have holes cut for the bolts? I'm wrapping up my 7030 open station restoration and want it as close to correct as I can. Thanks
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 9:16pm
Hello I have one on the shop floor .It is held down by 4 straps screwed to the floor .
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 11:04pm
Like 210 said it has a small c channel metal, with screws that go thru that into the platform. Cut on 45 degree angles on the front. If l ever get over to get that sign, l could bring you one and see if you could get it made.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 12:29pm
Okay thanks. I'm sure I could make them, but not having any idea what I'm making is the problem lol. I've had 3 open stations but none of them still had it.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 3:13pm
gits one of them horse mats from TSC, and cut to size/shape
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 10:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 10:29pm
look for quarter inch bolt holes in floor pans that will show you the hold down placement
