Open pollinated corn question
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Topic: Open pollinated corn question
    Posted: 13 Jul 2025 at 5:40pm
Planted some Jimmy Red corn, the plan was to grind, mash and brew it, but the entire field has tall strong stalks but not a single ear to be found.  It hasn't tasseled yet, got planted late due to rain, the seed was two years old as raccoons got last years crop and I had enough leftover to plant this year.  It was dry for a while after I planted it but not a drought by any means and it is bottom ground.  I just never experienced this before, any  answers or ideas?
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 6:06pm
I would wait to see the tasseling.
Do you have a plan for ground this fall? Like a cover crop that has certain ‘window’ to get in the ground?
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 6:07pm
Jimmy Red gets eight to ten feet tall. Just be patient with it. It will tassel first and then send up the ear.
Have you done the mash before or are both processes new? General advice is only do one new task at a time.
This forum may help, or so I'm told:
https://homedistiller.org/forum/
Another option is get oak smoking chips to put in a mason jar and fill with the bottom shelf cheapest vodka you can find. Wait some time. Then whiskey to bourbon depending on surface area to volume and time. It's a complicated mathematical equation... Lol.
Good luck!
Edited by jvin248 - 13 Jul 2025 at 6:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 7:22pm
I’ve got watermelon and cantaloupe intermingled now, last year, after the great raccoon heist, I disc it up and planted turnips.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 7:31pm
Good luck!
In my line of work, I have run into a few people that have various levels of experience, one was a distiller at a brewery before getting the government job. I have stalks 12 feet tall now, and I didn’t even get to put nitrogen on it because the wet weather and tractor show prevented the second cultivating. It’s just something I wanted to try, and making use of some of this copper lying around.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 9:05pm
JW I have some experience constructing stills from my previous life before retirement!
LOL
How's Joe doing? still working?
I am still confident of this;
Wait for the Lord;
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 7:00am
JW in MO, Sounds like you might have it planted it too thick? Jimmy Red Corn is recommended to have one plant every 12” within a row on 36” wide rows.
You did say it was planted late. So it will flower late. Maybe you also have high deer pressure, if so then I’d planted it thick too & then let deer eat/thin it?? How did you plant it? What is it’s emerged spacings?
Regardless, it should flower(ear silks then tassels). It just delayed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 7:30am
Lou; Joe retired at 77 due to bone spurs in his knees, Medicare fixed them, now he’s at Costco. Jeff Y. Got canned back in the spring during a big shakeup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 8:07am
[QUOTE=JW in MO]Lou; Joe retired at 77 due to bone spurs in his knees, Medicare fixed them, now he’s at Costco. Jeff Y. Got canned back in the spring during a big shakeup.
Good for Joe, sorry to hear about Jeff, good man[/QUOTE]
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 8:09am
32” rows, however I don’t know if some of the seed didn’t germinate or my planter messes up but leaning more toward planter as it’s more prevalent on one row. Spacing maybe 6,” but last year was no issue. Patience may be my biggest hurdle, got to leave town for a week, that will help
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 7:45pm
Six inch spacing is way too tight for heirloom corn.
GMO/hybrid and popcorn produces at 6 inches. Vertical leaves.
Corn emerges and looks around by V3-V6 to figure out competition. Then it carefully calculates the ear kernel rows and the length of the ear. At six inch spacing the stalks just tassel and put no ears on. Silage corn. Been there.
Stalks near skips will produce well.
You could try pulling stalks on a few rows to give you 12 inch spacing. Pull weaker or shorter plants.
I'm using 20 inch rows after 30 inch and 15 inch trials. Then 9-12 inch seed spacing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2025 at 8:10pm
Update, I found ears!!
#1. I wasn’t patient enough
#2. I was looking too low. Ears are just starting, barely visible, and above my head. Corn is starting to tassel, a good 10ft tall and I was looking from my golf cart.
This page was generated in 0.457 seconds.
