One-Wire Generator
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: One-Wire Generator
    Posted: 6 hours 54 minutes ago at 8:21pm
No, that is not a typo, this gadget truly is a one-wire generator.
I have several old generators (thanks ORBill) that I am finally getting around to testing. This unit is a third-brush type and has no provisions whatsoever for controlling the field current; a quick google search for the part number 943U shows that it is for a 1931-34 Studebaker. Some further searching led me to a Studebaker forum where I found schematics that clearly show this generator having only one wire leading from the armature to the cutout relay.
The amazing thing is that it actually works! I realize that I am probably the last person on earth to learn that this was at one time state of the art technology, but I have always been a bit slow on the uptake Embarrassed
8 Volts at ~8 amps Cool
My high tech generator test bench
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 59 minutes ago at 9:16pm
never heard of one wire gen ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 14 minutes ago at 10:01pm
Reckon I ain't never heerd'a sech neither Big smile But thar 'tis, right at the bottom of the diagram. The third brush picks off the field current from the armature, and the circuit is completed inside the generator by being grounded through the thermostat gizmo.
Whereas our familiar Allis-Chalmers charging systems give us the choice of manually selecting a high charge of ~10 Amps or a low charge rate of ~3 Amps, this unit simply provides a fixed charging rate of ~8 Amps depending on where the third brush is adjusted. The only other control is the thermostat which I presume to break the field circuit if it gets too hot.
Edited by Les Kerf - 5 hours 5 minutes ago at 10:10pm
Riprock View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riprock Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 36 minutes ago at 11:39pm
Some of the early 9N's used a one wire 3 brush generator.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riprock Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 27 minutes ago at 11:48pm
