One wire alternator
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: One wire alternator
    Posted: 20 Apr 2020 at 1:41pm
Is there any way to test a 1 wire alternator with a test light it's a positive ground.
Edited by 1947WC - 20 Apr 2020 at 2:11pm
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 3:36pm
I am guessing you are talking about checking alternator output. About the only thing I can see a test light will tell you is there is power at the alternator output stud, which it should have at all times on a one wire alternator. You need a voltmeter to see if the voltage changes when it is running. Positive or negative ground makes no difference in that. I have to ask this, Are you sure it is actually a positive ground alternator?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 5:57pm
Take it off and take in and have tested at the auto parts store. If your alternator has been hooked up POS ground your going to need a new one any way. The diodes are blown and it'll have no output. There are specitly shops that will make a POS ground alternator but they are very expensive. Negative ground became the world standard even before 12 volts became the standard voltage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 5:59pm
Check with a volt meter, at battery. volts running, vs volts not running...Hug
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 9:01pm
Thanks Jim.ME
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 9:08pm
Thanks Diy.Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 9:13pm
Thanks Dakota.Dave
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 9:24pm
Touch something metal to the bearing on the back of the alternator. If it magnetized, it is charging, if not it isnt
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 1:09pm
I'll try that. Thanks Adam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 1:16pm
if, IF, the test light was an LED, then yes.....though everyone has a voltmeter. Just be sure the test leads are in properly(red2red,bl2blk) !!!
99.44% of all alternators are NEG ground BTW....
