onan picture request
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: onan picture request
    Posted: 08 Apr 2016 at 6:56pm
I lost the pictures I took before I pulled my engine. Can I get pictures of how ccka throttle and choke cable are hooked up and routed on top of the engine. Thanks
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 11:04pm
dont know if mine is correct from the factory but i think it is will try to get pic tommorrow
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2016 at 11:05am
that would be awesome Hud, thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 7:03am
Any luck Hud?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 11:17am
got the pics to my e-mail will work on getting them on here hate to say it but it is a several hour trial and error prosess for my to do these kind of computer things
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 11:42am
if you want to email me them at coggonobrien@gmail.com i can post them up for other peoples reference
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 7:08am
Hud, not sure if you got my email or not but I received the pictures.  Is it possible to get a higher resolution picture without the air cleaner emailed directly to me?  I need to see how the cables connect to the carb
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 11:44am
i will get some new pictures the next time the sun is out took those with one of those apple smart phones but the pictures never turn out well unless its in full sunlight
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 11:49am
thanks hud, i'll pm you my cell number so you can just send them direct.  Tractor looks pretty mean with duals and a blade
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2016 at 7:49pm
Hud if you can also show me how the 2 cables are anchored to the sheet metal that would be great too.
Thanks!
Les Royer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2016 at 9:22pm
Actually, I just went through this same ordeal yesterday. But it's on a JOHN DEERE 420. Would that help?
I know what the correct routing is and it would be easier for me to be able to send the pictures to your phone, so PM me if you still need em. I'll be on later tonight.
Edited by Les Royer - 17 Apr 2016 at 9:24pm
I still gots my A/C but it's clear out in the barn now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2016 at 9:36pm
But it's actually quite simple really. And when I tell ya, yer gonna go well heil. Why couldn't I see that? Cause that's exactly what I did.  had to go through about an hour on the dang computer before I found sum pickshure showing the correct routing.
But here's how it goes on my JOHN DEERE 420.
The choke cable goes through the firewall. If ya look at the firewall from the front, I got 4 holes left to right. The choke cable goes in the 2nd hole from the right. Now this is looking at it from the front, ok? And thar should be a grommet in the hole. If thars not, you need sumthin around the cable to protect it from thet sharp steel. I just bought the grommet.
From thare it goes across the top of the motor and around the dipstick tube and into the cable holding bracket from the front of the tractor. I hope you got the heat sheilding there otherwise yer cable be riding on the muffler. And it ain't gonna last very long if ya leave it that way.
The throttle cable goes from the lever around the OUTSIDE of the firewall and into the govenor linkage. so it's positioned between the firewall and the side panel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 10:22am
fabbed all the mounts and blade brackets from a little help from all you guys out there
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2016 at 5:32pm
Well guys I figured it out today just need to find another cable retainer for the choke
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 6:59am
Here's pictures from Hudco for reference
This page was generated in 0.453 seconds.
