Onan cck engine rpm's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Onan cck engine rpm's?
    Posted: 17 Aug 2015 at 8:37pm
I have a Onan CCK engine on a generator. Low hours and very clean. It says RPM's is 1800, would it stand to be turned up to the 3600 rpm's like the CCKA and CCKB engines? Thanks Tracy
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 1:25am
prolly engineered to only do 1800 RPM;s for maximum generation!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 6:32am
Generator MUST turn at 1800 RPM to get 60 cycle power ! If you spun at 3600, you'ld generate 120 cycle power and probably damage anything plugged into it.Draw enough of a load and the genny will self destruct ($$$$$$$$).
If you need to replace or repower the genny you 'could' put a 2:1 reduction unit between the engine and genny......also 3600 RPM engines tend to be noisier than 1800 RPM ones.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2015 at 9:59pm
I am not going to use the generator. I want to transplant the engine in a AC 616. I know the crank and rods have to swap. Not sure about governor and cam.Any help appreciated. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2015 at 7:04am
I would think its pretty much the same engine and the rpm factor wouldn't be to critical. Like the guys mentioned, because its attached to a Generator, that's the reason for the lower rpms due to the Generating purposes. The only thing that I would be concerned with is the pulleys used on the Garden Tractor vs the Gennie. If the 616 had an engine and its bad, you may be able to swap over the pulleys to the Generators engine. Not sure bout' the crankshaft. You might have to do a little R&D on that Tracy to make sure things will interchange....
