On the hunt for a B&S Vanguard repair manual.. |
| Author | ||
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Topic: On the hunt for a B&S Vanguard repair manual..Posted: 04 Oct 2024 at 1:05am |
I am in need of a repair manual for an 18 HP V twin Vanguard Briggs And Stratton. Model=350447 Type = 1080-A1 Code= 96012 411 I've tried Ebay and Amazon but no luck so far,,,,? Anyone got an idee,,,??
Edited by desertjoe - 04 Oct 2024 at 4:40am |
| Sponsored Links | ||
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 04 Oct 2024 at 7:59am |
Just by chance Joe, is that engine in a Craftsman lawn tractor? |
Joined: 11 Sep 2009 Location: illinois Points: 90848 |
Posted: 04 Oct 2024 at 8:18am |
Posted: 04 Oct 2024 at 8:21am |
your not going to get that SPECIFIC... All Vaanguard engines would be VERY similar and all in the same manual... 18- 20 -22 - 24 HP all the same ... verticala shaft / horizontal shaft... ... AMAZON..
Posted: 04 Oct 2024 at 8:24am |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 04 Oct 2024 at 8:27am |
manual part number 272144 your local mower shop should be able to get it for you list price 38.84
desertjoe
Posted: 04 Oct 2024 at 8:29am |
Hey Lars,,I'm not sure,,most mower engines are verticle shaft,,the one I need is a horizontal shaft,,,Thanks.
desertjoe
Posted: 04 Oct 2024 at 8:31am |
Hey Steve,,I did look at this one,,but saw no mention of it covering the 350447 model,,,? Thanks,,!!
desertjoe
Posted: 04 Oct 2024 at 8:34am |
Thank you Hudco,,I'll look into this one,,,,Thanks
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25271 |
I used to download manuals from B&S website...maybe you still can ?? BTW yours was made Jan 24th 1996. I've been told Vanguards are the 'top of the line', better bearings and such but a LOT of 'common' parts. FYI the 'wires' connecting the coils to mag have diodes inside the heat shrink. If one diode fails open, that cylinder will still run....
Posted: 04 Oct 2024 at 8:37am |
Joe, as good of a mechanic as your are, i doubt you even NEED a manual... I took a horizontal shaft motor 15 years ago and MODIFIED a couple parts to use it as a vertical shaft motor... I rebuilt it last week without a manual... Pretty basic.. When i had a question, i just looked at You Tube for some details.... ALL the vanguard engines will have the same pistons / cam / clearances / specs.... Usually they just changed the bore 1/8 inch to go from 16 -18-22 HP output.. You can adjust the governor to get 3000 - 3600 rpm max speed... really that is the ONLY difference in all the Vanguard engines.
desertjoe
Posted: 05 Oct 2024 at 7:53am |
Well, Steve,,Many Thanks for the vote of confidence,,,,
Most times if I disassemble one, I do pay close attention and I can assemble it OK, and,,,,,and,,,I usually do find a place for all the nuts and bolts with no left overs,,,, I do like to have access to any wiring diagrams tho as some shade tree'ers do tend to cut wires during their troubleshooting,,,,,![]() |
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 06 Oct 2024 at 7:02am |
Posted: 06 Oct 2024 at 8:01am |
thats WAY over priced... I posted the same book from another vendor for 1/3 that price.. Same manual that HUD recommended.... there is only ONE BOOK that covers all those engines.
desertjoe
Posted: 07 Oct 2024 at 9:42am |
That's correct Steve,,,and that one is the one I caught at a "Reduced" price sale for,,,,,,$12.00 plus $5.25 shipping,,,!!! Many Thanbks to you and Hud for all your help. Ole Shameless did not call me "Thrifty" for nuttin,,, ![]() Now I'm on the hunt for a manual for an Onan CCK _5 _3F with SN of 510662353 (Those two missing numbers are not legible on tag) it is a horizontally opposed twin at 12.9 HP @2700 RPM this one may be a real old Timer
