Oliver 88 clutch |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1569 |
Topic: Oliver 88 clutchPosted: 28 Oct 2022 at 9:14pm |
I just bought an 88 Oliver diesel. The clutch was stuck so I tore the bell housing off to find the clutch was junk.
My parts man told me to go to the 4 puck style. He said the original style was not made as well anymore and they were giving him a lot of trouble So I did. Put the clutch in. Made sure the clutch was in place. Hooked everything up only to find the clutch doesn't do anything The pedal goes all the way down. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55280 |
Posted: 29 Oct 2022 at 5:02am |
Plate in backwards?
Dirt Farmer
Silver Level Access
Posted: 29 Oct 2022 at 10:32am |
Did you forget to put the throw out bearing back in or miss it with the clutch fork. Just a guess, not knocking you, we are all human and get distracted or make simple mistakes. Please report back cause we may all learn a thing or two. Good luck
bobkyllo
Posted: 29 Oct 2022 at 11:04am |
I had everything in as it should be. I did notice that when I tighten the pressure plate it sucks the fingers in a bit.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35678 |
Posted: 29 Oct 2022 at 3:21pm |
Plate is in Backside IN and Front Side OUT.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 29 Oct 2022 at 10:59pm |
Don't know if there is a general rule for which side the springs are facing but the hub must clear the flywheel bolts.....it only works in one position. Yours may be reversed as Dave says. (his English gets me sometimes LOL)
fixer1958
Posted: 30 Oct 2022 at 7:24am |
It will suck the fingers in when tightening. I think the disc is in backwards.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4077 |
Posted: 30 Oct 2022 at 7:23pm |
if the disc is backwards probley would not boltup or tighten around the flywheel without a gap i would think probley fork or throw out bearing , or someone modifiyed the linkage to get more out of the clutch than it was suposed to do
SteveM C/IL
Posted: 05 Nov 2022 at 6:05pm |
Did this ever get resolved?
