Oliver 88 clutch
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: Oliver 88 clutch
    Posted: 28 Oct 2022 at 9:14pm
I just bought an 88 Oliver diesel. The clutch was stuck so I tore the bell housing off to find the clutch was junk.
My parts man told me to go to the 4 puck style. He said the original style was not made as well anymore and they were giving him a lot of trouble
So I did. Put the clutch in. Made sure the clutch was in place. Hooked everything up only to find the clutch doesn't do anything
The pedal goes all the way down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2022 at 5:02am
Plate in backwards?
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2022 at 10:32am
Did you forget to put the throw out bearing back in or miss it with the clutch fork. Just a guess, not knocking you, we are all human and get distracted or make simple mistakes. Please report back cause we may all learn a thing or two. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2022 at 11:04am
I had everything in as it should be. I did notice that when I tighten the pressure plate it sucks the fingers in a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2022 at 3:21pm
Plate is in Backside IN and Front Side OUT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2022 at 10:59pm
Don't know if there is a general rule for which side the springs are facing but the hub must clear the flywheel bolts.....it only works in one position. Yours may be reversed as Dave says. (his English gets me sometimes LOL)
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2022 at 7:24am
It will suck the fingers in when tightening. I think the disc is in backwards.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2022 at 7:23pm
if the disc is backwards probley would not boltup or tighten around the flywheel without a gap   i would think probley fork or throw out bearing , or someone modifiyed the linkage to get more out of the clutch than it was suposed to do
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 6:05pm
Did this ever get resolved?
