older Dodge pickup |
D17JIM2
Joined: 01 Jan 2013 Location: Brazil, In Points: 246 |
Topic: older Dodge pickupPosted: 15 May 2018 at 6:58am |
My sons Dodge pickup that i had posted about be fore has a problem I can't help him with.
It had sat for several years and we put a new heavy duty battery in it, started it and drove it about 20 miles home. After several small issues his daughter was driving it while her care is in body shop and yesterday it wouldn't start when she got in it to leave school activities. It is a 225 slant six and was running great. 1984 is the model year . Model 100 2w drive. Only less than 200 miles since he got it going. The truck dies if you disconnect the battery. He got a good spark to the battery when he disconnected to see if it would run off the alternator. He took the alternator to have it checked and it checked fine at auto store. He cleaned the ground to the frame and all connections are clean. I'm stumped. It does start when it's jumped but will only start once, then its the same as before. Any ideas as to what to look for. Thanks, Jim Edited by D17JIM2 - 15 May 2018 at 6:59am |
copyrite1972
Posted: 15 May 2018 at 10:28am |
Voltage regulator? Fuse? Maybe broken charge wire to the battery? Flux Capacitor out of sync with the #4 turbo (jk!)?
D15 Series II
D17JIM2
Posted: 15 May 2018 at 10:42am |
No turbo on 225 1984 slant six gasser.
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 15 May 2018 at 11:16am |
Flux capacitor came out in the 1985 model I believe.
1957 WD45 dad's first AC
weiner
Joined: 19 May 2012 Location: Cadillac, Mi. Points: 4304 |
Posted: 15 May 2018 at 11:51am |
I`m not familiar with a flux capacitor. I have owned a number of these old Dodge pickups and cars. The first thing I would buy and have a spare in the glove box is what I called a resistor, an oblong white ceramic box that was about 2 inches long and mounted on the firewall. (engine side) Eventually it would fail and the engine would not start. The newer ones had a double resister that would allow the engine to start, but then stall. (Similar to the internal resister in a coil??)
I would try that and if that is the problem, buy an extra one for your glove box, just to be safe.
Edited by weiner - 15 May 2018 at 11:54am |
Real heros wear dogtags, not capes.
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11858 |
Posted: 15 May 2018 at 12:32pm |
It doesn’t start, but does it spin over and just not fire? More info needed.
And does it have any spark during those periods when trying to start it? Just because it doesn’t run without a battery doesn’t really prove much. You need a voltmeter. |
D17JIM2
Posted: 15 May 2018 at 12:39pm |
It starts if jumped. Dies if you disconnect the battery.
Will not start after you shut it off. Meter on truck dash says it's charging. Altternator was taken off and tested at Auto Zone and showed it was good. Battery has maybe 200 miles on it and is heavy duty battery. If resistor was bad would it start if jumped. |
alan-nj
Joined: 12 Sep 2009 Location: oxford, nj Points: 847 |
Posted: 15 May 2018 at 12:57pm |
it might...resistors failing on those was very common... its been a few years, but I'm remembering them a tad bigger than noted above, maybe 2 x4 in size, white porcelain/ceramic. back then they were cheap.....today??
If ignorance is bliss, than happy days are here again.
D17JIM2
Posted: 15 May 2018 at 1:24pm |
Thanks guys for a couple of things to try.
We put a resistor on the heater and had to get one on line . Nobody had them for this old a truck. Over $20. Some one told me that this problem is probably the regulator. It's mounted in the fire wall and has avtriangle plug. He's replaced many back in the day. Thanks again, Jim |
Greg (Hillsboro, OH)
Joined: 11 Sep 2009 Location: Hillsboro, OH Points: 1198 |
Posted: 16 May 2018 at 11:15am |
the part you need can be found at O'reilleys auto parts. Do a search on their website for part 121G.
D17JIM2
Posted: 16 May 2018 at 11:20am |
My son used O'Reilly so that works ! Thanks
HD6GTOM
Posted: 18 May 2018 at 12:47am |
I had a dodge van, same problem. My firewall resistor was black. If they are gonna keep the truck, as stated above, buy 2 put one in the glove box along with the tools to change it. They will need it.
D17JIM2
Posted: 18 May 2018 at 3:49pm |
It was the Voltage regulator. An old mechanic told us. He also said to keep a resistor. The VR was real easy to replace.
He charged the AC and it seems to hold . Amazing ! Thanks again. |
shameless dude
Posted: 18 May 2018 at 3:57pm |
I don't know if this will help, I had a hagie high boy sprayer with that slant 6 in it, it died on me in the field while spraying and wouldn't restart. an old boy that worked for Dodge said to take the starter in and have it rebuilt and then it will start! and after a 100 questions and answers back and forth, I finally took the starter off out in the field, took it in and had it rebuilt and put it back on, it started right away and ran good ever since! that old dude said the starters will make them die sometimes.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 20 May 2018 at 12:10pm |
A car or truck WON'T RUN with the battery disconnected. They would with a generator, but not an alternator.
Battery was failing because of a faulty VR. But yes, keep an extra resistor in the glove box. Had one fail on me years ago. Drove it home and it wouldn't start the next morning. Jumping it wouldn't work either. |
