Old Transmission Brake Pictures
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: Old Transmission Brake Pictures
    Posted: 17 Jul 2010 at 11:51am
I thought I would share these pictures of the transmission brake out of my 7000.  Good thing I got the NOS one on ebay a while back to keep in my parts bin.
This explains the pieces of friction material I found in the bottom of the hydraulic sump a couple years ago.  It matches the exact same material as the brake pad is made of.
Hurst
1979 Allis Chalmers 7000
5800 Hours
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 1:13pm
was it much of a job to change it out do you have to split the tractor to change one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 3:16pm
Just had to drop the fuel tank, pull the powershift valve, and then knock out a roll pin and bend my arm in some weird ways to get it out.  It has a big pin that holds it in place and is also what actuates it.  It's hard to explain with words, but if you take the powershift valve off and look up to the top rear of the clutch pack, you will see it.  This is just on the 7000, the 7010 and up have a different design.
Hurst
5800 Hours
