Old Tractor Tune Ups
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Old Tractor Tune Ups
    Posted: 28 Oct 2017 at 12:21pm
I am sitting here just getting ready to eat some lunch thinking about a tune up on one of my 45's so I got to thinking if you guys just set the points with feeler gauge and call it good or more over am I one of the last old guys left that uses a dwell meter to set the points. Please don't make me feel old and say to just use a feeler gauge. lmao
After lunch I'm going to tune her up and get back to working ground up for the winter.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 2:02pm
Setting points with a feeler gauge has worked for all recorded history of magnetos and distributors. Some GM products required the dwell meter because of bad access to the points. It works too. Remember that when you change the point gap, you also change the ignition timing because the distributor cam has a gentle slope.
Gerald J.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 2:35pm
Feeler gauge works . I adjust timing and carb adjustment using a vacuum gauge . Set plug gap and Check valve lash with a wire type thickness gauge , flat feeler gauges are not the best with a worn valve train .
And unless your points are burnt
the capacitor is fine to reuse with new points as new capacitors can be junk right out of box .
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 6:28pm
What's a dwell meter......? LOL! Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 6:40pm
So if I set the points on a 50 year old tractor with lets just say now has over 7,000 hours on it at the factory air gap of lets say where .020" for the distributor when it was new then the dwell angle will still be at the new factory dwell angle of lets say was 31* to 34* this 50 year old tractor will still maintain the same dwell angle at the air gap of .20" or will it change the dwell?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 8:18pm
I needs to get some of them feeler gauges, my matchbooks is gettin wore out...Wink
drobCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 8:54pm
my 2c sez more power to whoever keeps these old beauties running decent by whatever means they prefer.
I'd gauge most people feel similar, but I don't want to dwell on it.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 11:19am
Using a Dwell Meter is the best way to do it. Feelers get pretty close, but you're measuring the time the points are closed with the meter which is what the coil cares about. Now if you really want to be accurate, get one of those old Sun machines so you can see where each point closing event and spark plug voltage peak happens. IIRC there's 3 settings on the scope, display, raster, and super impose. Makes it easy to spot worn distributor cams, loose shaft bushings and advance mechanisms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 12:46pm
Brian, I've been looking for one of those old Sun machines for a long time.  You'd have to go to an auction of some old guy who ran a shop out of his garage to get lucky.
Don, I set em with a feeler gauge first and then check them with the dwell meter.  I've always had good luck that way.
As per your question, it shouldn't change the dwell, "theoretically" at least.  Too many variables, but I really doubt that it would, if everything is in 'good' shape.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 2:48pm
Cam wear may affect the dwell/gap ratio, but I suspect that it would take a lot of wear to make much of a difference.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 5:42pm
i use a dwell meter when i can ,   sure makes a differance even if you check a few lobes with the feeler gauge the dwell meter will still make it better  hard to beat the vacuumm gauge over the timing light some times.     i still have a perfect operating 1160 sun machine that i like to use, and put all the scanners and hand held stuff away
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 6:04pm
You just HAD to TACH that on, dintcha???Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 6:20pm
Don,
 I still use feeler gauge. I don't think I could run or understand a dwell meter! Had poor spark on the WD the other day. used a Emory board to dust them and a dollar bill to clean them.Eyeballed them at .020! Fired right up once we had sparky!
Edited by Sugarmaker - 29 Oct 2017 at 6:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 6:40pm
On a low RPM 4 cylinder engine it doesn't matter that much. Too high a dwell might cause the coil to heat more than it needs to, but I don't think it would be an issue. You had to use a dwell meter on those old GM cars before they switched to the HE system. Nonetheless a dwell meter is not hard to use. I'm looking around on Amazon and I see some for about $30.
Edit: One advantage of setting the dwell is the points get set almost exact each time. If you set the points exactly the same each time your timing won't follow your gap error and change in proportion with it.
Edited by DougS - 29 Oct 2017 at 6:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 4:29pm
What I was trying to find out was who still use's a dwell meter, but thanks for all the input.
Here's part of the question I asked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 5:22pm
Don, wish I was up at the farm so I could take a picture of my dwell meter for ya.  I bought it somewhere in the late 50s or the early 60s.  I use it all the time, but that don't make me old.......my birthday does that.  LOL
Using one on the Chevy V-8s was absolutely necessary at the time, cause they had that little window you'd lift up.  Made it SO easy to do.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 7:50pm
You see Don I use a feeler gauge to set the points and everything else.  So now several months later I burn up the points or condenser I buy a new set and start all over.  Now if I take it to you and you set everything and several years later it burns up I get to bring it back to you for warranty cause you touched it last!
Signed,
John Q. Public
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 7:52am
Signed,
John Q. Public
OK to john Q. for you I will make a good deal on warranty. lmao
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 12:34pm
I'd use a Dwell meter, but the only engines I have on the place with points are single cyl Kohler, B&S, Clinton, Wisconsin, Onan, Cushman. Those are the ones I can think of. I collect old small engines and stopped counting when I hit 50. Most of them are common dime a dozen. These days I watch for the orphans and odd balls...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 12:41pm
If the points open 5 degrees (on the cam) later, which is a very small amount of turn, the engine timing will be off 10 degrees. Perhaps it doesn't matter that much on an old low-compression slow RPM engine, but it can be significant on a more efficient engine. Dwell is more accurate.
