Old oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: Old oil
    Posted: 21 Feb 2023 at 3:40pm
OK,  I just scored 6 cases of 10W40, 24 cans per case )
Shell SUPER multigrade motor oil
one QUART(1.14l) cans !!
These are the cardboard cans with steel ends
SO the 64,000$ question....
Anyone know how OLD they'd be ?
more important follow up...
Does anyone KNOW where my oilcan spout with piercer is ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 4:41pm
I no longer have my piercer spout
Last can oil I saw as a mechanic was around 1980-84
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 4:48pm
YEP.. Dave got it..
Composite / Cardboard Quarts:
There are many names for the quarts that are constructed of a heavy cardboard with a metal top and bottom. Some collectors also refer to this type of can as simply a paper quart can. Composite quart cans started to appear in the late 1940's but they were adopted by most companies by the late 1950's and were used until the late 1980's. There are a couple of variations of the composite quarts that we'll discuss below.
Edited by steve(ill) - 21 Feb 2023 at 4:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 4:50pm
the addatives in oil tend to separate out after several years.... shake them up, or put in  bucket and stir good prior to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 5:31pm
Do the cans have a UPC code on them?
What rating is the oil? (Sa-p)  Oldest won't have a rating or a low rating, like Sa...)Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 5:39pm
Older Oil SPECS.... i dont think Jay OWNS anything newer than 1980 !!!  Wink  Big smile
Category
Status
Service
SPCurrentIntroduced in May 2020, designed to provide protection against low-speed pre-ignition (LSPI), timing chain wear protection, improved high temperature deposit protection for pistons and turbochargers, and more stringent sludge and varnish control. API SP with Resource Conserving matches ILSAC GF-6A by combining API SP performance with improved fuel economy, emission control system protection and protection of engines operating on ethanol-containing fuels up to E85.
SNCurrentFor 2020 and older automotive engines
SMCurrentFor 2010 and older automotive engines.
SLCurrentFor 2004 and older automotive engines.
SJCurrentFor 2001 and older automotive engines.
SHObsoleteCAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1996. May not provide adequate protection against build-up of engine sludge, oxidation, or wear.
SGObsoleteCAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1993. May not provide adequate protection against build-up of engine sludge, oxidation, or wear.
SFObsoleteCAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1988. May not provide adequate protection against build-up of engine sludge.
SEObsoleteCAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1979.
SDObsoleteCAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1971. Use in more modern engines may cause unsatisfactory performance or equipment harm.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 6:06pm
I have one of those piercing spouts. Somewhere. Fav son saw it years ago and asked what it was. Thanks
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 6:29pm
I ain't seen one of those spouts in decades.  LOL
Good idea about mixing them up.  I have seen those additives settle out on old oil.
So what you gonna do with it?  Reminds me of the day when my dad would only pour Trop Arctic in his flat head Plymouth outta one of those spouts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 7:35pm
 Dang had to get the bifocals on....
 it says......API service SE (formerly MS )
So should be OK for the fleet of 1957 D-14s here ??
Wonder if it'd be 'ok' for lawn mowers and riders ??
I KNOW it's going into the A-C forklift with Buda BD153. It likes anything.
Crazy thing is the EMPTY cans are 'collectable' !! At $25 each.....
Edited by jaybmiller - 21 Feb 2023 at 7:37pm
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 7:42pm
if 'selling the cans best to open at the bottom of the can' looks a lot better.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 8:58pm
Turn the cans upside down for a month or so, then give it a good shake before opening.
I still have one old spout left, but in my teen years I just used a knife.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 9:08pm
Remember the tv commercial showed a guy using a Bic pen to open those old style oil cans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 9:34pm
someone thought these'd be good for real 'hot rod', oil may have zinc in them ?
I gotta find my real opener gizmo though, dang curious to see what's inside...
it's Christmas again !!!
Too bad they don't say Allis-Chalmers on them though.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 10:06pm
Think there's still some Quaker State 20wt non detergent in metal quarts up in dad's shop. That's what he used after O/H to break things in. Been there since early 80's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 9:03am
update...so.. SHELL gets back, asks me to look at the date code on the cans, I ask WHERE is that.....
also says the additives are no good anymore....
I asked WHY ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 4:00pm
i always heard the additives are still there, just settled out in the bottom... After 40 years, i dont know, but after 10-15... you just stir them back up..
you said the cans are worth a fortune.. why not sell them WITH THE OIL and take the money to buy NEW oil ?
Edited by steve(ill) - 22 Feb 2023 at 4:06pm
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 4:30pm
I found 2 old quart cans in some junk from an auction maybe 5 years ago. The Cardboard fell apart when I tried to open with church key. Open very carefully !!
 Be Good oil for use on open chains, or a GREEN tractor engine.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 4:52pm
Some of the 10/40 oil was not designed for later model engines as they required over a 10 weight but the multi 40 was lacking something for late 80's engines ,
 Yet if you have some older thins that had 10/40 spec - use it - it's batter than the $4.00 or more they now want for a quart .
Also it could be used for hydraulic oil in most equipment with no problem as 10/30 is spec on many hyd systems
Edited by Coke-in-MN - 22 Feb 2023 at 4:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 5:26pm
more digging....
while Shameless machine makes purdy here....
API says 1972-1979 era cars
gonna put ads out later....
seems guys poke 2 holes in the bottom to drain,probably real fast with a sharp awl.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 6:19pm
Dorix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dorix Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 7:06pm
I just saw yesterday in the garage some cans of Mobil, I think, and my dads old spout.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 7:21pm
+ 8 bucks shipping.
 Tossed out about a dozen of them last fall... just in my way. Ssome were like chromed and a couple were painted.
mmm, Maybe should use em to jam them in the butt of the plastic bottles so to use in them hard to reach filler spouts that ford would bury below the pipes and hoses in the engine compartment.  LOL Maybe not, prolly end up with a bigger mess. Ermm
This page was generated in 0.348 seconds.
