Old member. New toy |
| Author | ||
DREAM
Joined: 06 Jan 2010 Location: Elberton,GA Points: 1836 |
Topic: Old member. New toyPosted: 07 Apr 2026 at 8:02pm |
Hey everybody, long time no type.
Lets just say life got REALLY busy for me for awhile. Still have my 46 C. Just aquired a bucket list(for me) tractor completely by chance. Gonna see if i can remember how to get pics on here, and then ive got a few questions... First question though is "hows everybody been?" |
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
| Sponsored Links | ||
DREAM
Posted: 07 Apr 2026 at 8:13pm |
Ok, i cant remember how to do the pictures. Used to use dropbox, but cant remember how.
Anyway, i found myself a fairly clean, mostly complete 1949 AC model G. Has hydraulic lift front and rear. Has headlight still in place. Came with a full set of AC cultivators. Also came with what i believe to be an Athens brand disc plow, and a Bush hog brand belly mower. Ive just started tinkering with it, and the starter is going to need some help. Looks like it may have been hit with 12 volts a few times. Im still not sure, but the battery that came in it "looks" like a 12 volt. Has 6 water holes. Tractor has also jad a Ford 12 volt coil installed, but still has tje 6 volt Delco remy gemerator and some questionable wiring. Still has tje cutout and 2 position charge selector switch that seem to still ne doing thimgs. Tje genny field lead has been spliced and grounded to the dash panel. Not sure whats up with that. Im going to check to see if my local guy is still in business doing starter/generator work to see if he can get brushes for tje starter, clean up the commutator, and see if starter/generator are burned up. Generator field winding ohms out at around 3 ohms, so? Any help is greatly appreciated. |
Les Kerf
Posted: 07 Apr 2026 at 8:51pm |
Apparently they converted to 12 volts and instead of doing a proper conversion they just full-fielded the generator to force it to charge the 12 volt battery.
3 Ohms is right in the ballpark
DREAM
Posted: 07 Apr 2026 at 9:09pm |
Thanks for that! Sounds like they just did a budget 12 volt conversion.
Im not sure what the right way forward is on that. I know the starter will handle 12 volts, as long as its not spun over for long periods of time. My C jas only had a 12 volt battery as long as ibe had, and it does fine. I cut the genny leads and jist charge the battery if i need to. It has a mag, so no need to give power to ignition. I just dont want to burn up that generator if its still good, and i need a way to power the ignition on the G, since it has a distributer. What about going to an 8 volt battery? Maybe a little more "kick". Manual says the system is good for 6 to 8 volts. |
DREAM
Posted: 07 Apr 2026 at 9:12pm |
I really just need to get the starter rehabbed and then see what kind of shape the engine/trams/hydraulics are in before i get too deep.
Gas tank looks like new on the inside BTW, as does the radiator, so small wins there. |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9001 |
Posted: 07 Apr 2026 at 11:17pm |
Has been a spell since I seen your name on a post. Good to see you're still on top of the dirt.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8781 |
Posted: 08 Apr 2026 at 5:12am |
Welcome back to the forum. Good to hear from you again. My latest acquisition was also a G. Wasn't exactly on my dream bucket list, but it came along and I thought that I had to have it. It'll be a "work in progress" for quite some time, I am sure.
Darrel |
Les Kerf
Posted: 08 Apr 2026 at 1:56pm |
There is nothing technically wrong with converting to 8 Volts; the only drawbacks are the cost and relatively low availability of 8 Volt batteries, and the hassle of charging/jumping a dead battery. My late Father-in-law ran his WD on 8 Volts for decades.
DREAM
Posted: 08 Apr 2026 at 7:35pm |
Good point about the charging a dead battery part. Hadnt thought of that. Ive got a 6/12 volt charger, so thanks for that.
DREAM
Posted: 08 Apr 2026 at 7:36pm |
You too Steve! Hope everyone is well up your way.
DREAM
Posted: 08 Apr 2026 at 7:38pm |
Thats exactly what happened to me Darrel. Wasnt planning on buying another tractor at all. Already too many projects going on, BUT like you said...just couldnt pass it up.
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6622 |
Posted: 09 Apr 2026 at 7:54am |
Good to see you back. I had been wondering what happened to you. That little G is a nice tractor with the implements you have. I would consider changing it to a 12 volt system with a rebuilt generator or alternator with avoltage regulator and new coil.
Have you tried Booty’s in Royston lately? The last time I was there a year or two back the food wasn’t that great.
