Old craftman B&S ?
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Topic: Old craftman B&S ?
    Posted: 14 May 2016 at 2:20pm
I have a old craftman mower that is about 20 years old, with a B&S engine in it. It starts fine, no smoke and runs fine! The oil was changed on a regular time frame. The issue is I do believe that a rod or bearings are about to explode!! It has a louder that normal sound to it.
What, if anything do anyone recommend to put in the oil to try to "buy time" till the explosion! I am not going to put much or any big money in to it for the rest of the mower is wearing out.
I didn't now if Lucas oil treatment, or something similar would help out?
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 2:21pm
STP
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 6:34pm
Hmm - could look inside and see how bad things are - I had a Tecumseh that seized on the rod bearing - took it apart - used caustic soda to remove aluminum from journal - polished it lightly - then took brake hone and polished inside or rod - then plasti-gauged it to fit rod by scraping joints on cap to rod polished it again with hone until
 Ran for another 2 years -
This page was generated in 0.414 seconds.
