Ok I did it, now I need to fix it!
offdutyangler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote offdutyangler Quote  Post ReplyReply Direct Link To This Post Topic: Ok I did it, now I need to fix it!
    Posted: 22 Aug 2014 at 4:04pm
First I will start by saying “I know now not to do this and that I’m a dumba$$)
Anyways, I pressure washed my A/C 712h (everything including the engine) and now it’s starting really hard. I let it sit for three days and still it’s really hard to start.
What did I do?
And
What are some solutions for fixing it?
(Prior to me washing it, it started really easy and I never needed to use the choke.)
1941 "WC" and a 1976 712h
dustydoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2014 at 4:40pm
does it start at all or just crank over.I would check the air cleaner if wet  wont start
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2014 at 9:13am
That's what I was thinking when I read your post. A wet n' watery air cleaner....
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2014 at 12:48pm
is it a kolher k301 12 hp if it is dry and clean and adjust the pionts i think .018 drain offthe fuel carb bowl
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2014 at 3:37pm
also remove spark plug wire out of coil and dry it
Post Options Post Options   Thanks (0) Thanks(0)   Quote offdutyangler Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2014 at 8:07am
Back to normal, thank guys.
This page was generated in 1.801 seconds.
