Oil Viscosity?? |
| Author | ||
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: Oil Viscosity??Posted: 14 Sep 2021 at 7:33pm |
The vehicle that I run calls for 5W20 oil, my wifes 5 year old 'newer' buggy calls for 5W30 oil. I would like to consolidate oils but am unsure which viscosity to stock up on
Thanks
| Sponsored Links | ||
bemer848
Bronze Level Access
Joined: 29 Sep 2013 Location: southern IL Points: 93 |
Posted: 14 Sep 2021 at 8:01pm |
Have you ever heard of google? Oh I forgot you are trying to get to the 4000 post mark.
Joined: 11 Sep 2009 Location: illinois Points: 89789 |
Posted: 14 Sep 2021 at 8:08pm |
18 post to go !! Your almost an ADULT !!!
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8330 |
Posted: 14 Sep 2021 at 9:36pm |
Consult the owners manual of both vehicles, most give different ‘preferences’ of weights of motor oil. If both have a common grade in that list, go with that one. |
Posted: 14 Sep 2021 at 9:51pm |
manufacturers changed to 5W20 , a thinner oil, to help gas mileage. Most of those motors were originally 5W30 type....... If a newer auto requires 5W30, its normally because it works harder ( like a turbocharger) and needs a thicker oil for extra heat.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25006 |
Posted: 15 Sep 2021 at 5:47am |
then there's the 'winter-summer' thing. you need different oil based upon the temperature..coruse with CC warming up the world, you won't need a 'winter grade' oil anymore.....
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12358 |
Posted: 15 Sep 2021 at 7:03am |
Hunch only, but your vehicle is older, has some wear and some clearance, 5W30 would be just fine for yours. And still 5W for easy flow at start up. Do as you will.
Lars(wi)
Posted: 15 Sep 2021 at 7:30am |
I have a 2004 Ford Taurus, it calls for 5w-20, most of its life I used 5w-30 full synthetic. Tried 5w-20 a couple different times, but oil consumption always increased. So whatever mpg gain there may have been, was canceled out by the increased oil usage.
FREEDGUY
Posted: 15 Sep 2021 at 7:34pm |
Thanks . My 5.4 is pushing 195,000 miles, the wifes buggy is 128,000 . Her Nissan Rogue is not T/C though in response to another poster
. Thanks guys |
FREEDGUY
Posted: 15 Sep 2021 at 7:36pm |
I haven't changed viscosity between "summer/winter" since 1998
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10262 |
Posted: 15 Sep 2021 at 8:00pm |
Over 350,000 miles on my 1999 Toyota 3.0 V-6 Camry. 1 quart in 5,000 miles. Using Castrol 5w-30 GTX motor oil. Never had to open remove the pan or heads. Runs strong as a new one.
Brian Jasper co. Ia
Posted: 16 Sep 2021 at 12:31am |
Stock up on both. It’s not a good idea to use other than what the manufacturer recommended.
Tbone95
Posted: 16 Sep 2021 at 6:29am |
Ya, me neither. There's usually a recommendation that covers a very large range of operating temperatures on anything I've owned for the last few decades.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34501 |
Posted: 16 Sep 2021 at 9:11am |
Some vehicles today require full synthetic,
but with 195,000, maybe you better not switch., just stock up on both oils. and just label them 'HIS' and 'HERS' just so you know which is which.
