oil pump |
1946WP
Topic: oil pumpPosted: 29 Jan 2011 at 7:25pm |
has anybody rebuilt an oil pump? I'm not sure what to look for & what replacement parts are available. there are like swirl marks on cover & the cyclinder. I think its ok to to smooth down the swirl marks on cover but not on the pump cycl I can replace the springs & check ball.does anybody have any advice or tips .
![]() some pictures of one oil pump w/ swirl marks Thanks for advice.
CTuckerNWIL
Posted: 29 Jan 2011 at 7:44pm |
The most critical part of repair would be getting the clearance between the vanes and the housing set right. Probably .002 or less I don't know. If the swirls are removed from the "cylinder" you would have to grind the top plate to make the depth of the cylinder the same as the height of the vanes, then add a .002 gasket for clearance.
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 29 Jan 2011 at 9:44pm |
The top plate is to be flat and the clearance is set by using multiple gaskets. They come in different thicknesses. If you tolerance isn't correct you will lose prime in your pump. Bob
CTuckerNWIL
Posted: 30 Jan 2011 at 10:42am |
I didn't make myself very clear. If you grind out the grooves in the bottom of the cylinder, then you will have to grind off the top of the "cylinder" to keep the depth of the cylinder the same as the length of the vanes. Yes the top plate should be flat.
1946WP
Posted: 30 Jan 2011 at 1:40pm |
thanks guys, but how do you check the clearance between the cover & vane with the cover on? do you use a straight edge over the surface & measure clearance, before you put the cover on?
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4812 |
Posted: 30 Jan 2011 at 2:17pm |
Would the plasti-gauge stuff work that you get from the parts store for measuring bearing clearances?
CTuckerNWIL
Posted: 30 Jan 2011 at 7:26pm |
Measure the depth of the "cylinder' with a depth mic and mic the width of the vanes. they should be the same. Your gasket sets the clearance.
Another way would be to put a straight edge over the "cylinder" with the internals in it. The vanes should be flush with the top of the "cylinder".
