Oil pump drive pin
Robin Heckman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robin Heckman Quote  Post ReplyReply Direct Link To This Post Topic: Oil pump drive pin
    Posted: 17 Jun 2025 at 6:26pm
Does anyone know the size pin is used on oil pump drive pin on a CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2025 at 7:46am
Hello welcome to the forum. I sent you an email
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2025 at 8:38am
If the pin is loose - you may have to repair the hole or use a slightly larger pin or spiral pin to be tight.
juniorp53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2025 at 9:10am
5/32 x 1 1/4 dowel pin from mcmaster is what i used , no problems  used an  air hammer to peen the ends  ....i seem to recall people asking about using a roll pin,  others that may no longer be with us here on the forum advised against it
