Oil priming a c oil pump |
3rd generation
Topic: Oil priming a c oil pumpPosted: 21 Jan 2026 at 1:15pm |
Just about to start a freshly rebuilt 1944 C engine.
My thought is to use an oil extraction pump to push oil into pump and engine. I could use the pump for my boat motor if it doesn’t work. Is primming these pumps needed considering the pump does not sit in the oil pan. I resurfaced pump to .0025” |
Joined: 11 Sep 2009 Location: illinois Points: 90608 |
Posted: 21 Jan 2026 at 5:35pm |
it may prime on its own... but you can take the 1/4 inch tube off going to the filter and use a squirt gun to fill the tube and pump prior to cranking..
remember, this is a BYPASS System... you dont have to FILL the filter.. The pump pushes 85% of the oil thru the cam shaft to feed all the engine bearings... 15% of the oil goes to the filter to clean and dump back to sump.. Edited by steve(ill) - 21 Jan 2026 at 5:38pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4063 |
Posted: 21 Jan 2026 at 6:31pm |
i use a weed sprayer to pre lube all my new engines i just hook into the oil preasure gauge port mostly
Les Kerf
Posted: 21 Jan 2026 at 6:55pm |
DickL has posted his method which is to remove the oil filter and slip a snug fitting hose over the metal tube that Steve described above. He then uses a small funnel to fill the hose and lets it gravity feed down, maybe repeating this a couple of times. Then, leaving the valve cover off, allow the hose to hang into the valve area in order to verify that oil is actually flowing upon initial startup. This method also provides for observing the flow of oil to the rocker arms. I only recently learned of this method, but I intend to do this on my next fresh startup.
3rd generation
Posted: 22 Jan 2026 at 7:57am |
Good info. Under normal flow does the oil exit the stand pipe from pump?
Les Kerf
Posted: 22 Jan 2026 at 8:20am |
Yes. As Steve mentioned above, the majority of the flow goes through the hollow camshaft to the internal parts of the engine (weird, huh?) and roughly 15% is diverted to the oil filter and governor drive via those external oil lines.
Posted: 22 Jan 2026 at 9:13am |
If you just TAP IN to the line, most of your aux pump oil will go thru the filter and dump back to sump... You dont need oil toward the filter, you need to push the oil BACKWARD thru the tube into the PUMP and hollow CAM..
