Oil priming a c oil pump |
3rd generation
Topic: Oil priming a c oil pumpPosted: 19 hours 31 minutes ago at 1:15pm |
Just about to start a freshly rebuilt 1944 C engine.
My thought is to use an oil extraction pump to push oil into pump and engine. I could use the pump for my boat motor if it doesn’t work. Is primming these pumps needed considering the pump does not sit in the oil pan. I resurfaced pump to .0025” |
Joined: 11 Sep 2009 Location: illinois Points: 89701 |
Posted: 15 hours 11 minutes ago at 5:35pm |
it may prime on its own... but you can take the 1/4 inch tube off going to the filter and use a squirt gun to fill the tube and pump prior to cranking..
remember, this is a BYPASS System... you dont have to FILL the filter.. The pump pushes 85% of the oil thru the cam shaft to feed all the engine bearings... 15% of the oil goes to the filter to clean and dump back to sump.. Edited by steve(ill) - 15 hours 8 minutes ago at 5:38pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4032 |
Posted: 14 hours 15 minutes ago at 6:31pm |
i use a weed sprayer to pre lube all my new engines i just hook into the oil preasure gauge port mostly
Les Kerf
Posted: 13 hours 51 minutes ago at 6:55pm |
DickL has posted his method which is to remove the oil filter and slip a snug fitting hose over the metal tube that Steve described above. He then uses a small funnel to fill the hose and lets it gravity feed down, maybe repeating this a couple of times. Then, leaving the valve cover off, allow the hose to hang into the valve area in order to verify that oil is actually flowing upon initial startup. This method also provides for observing the flow of oil to the rocker arms. I only recently learned of this method, but I intend to do this on my next fresh startup.
3rd generation
Posted: 49 minutes ago at 7:57am |
Good info. Under normal flow does the oil exit the stand pipe from pump?
Les Kerf
Posted: 26 minutes ago at 8:20am |
Yes. As Steve mentioned above, the majority of the flow goes through the hollow camshaft to the internal parts of the engine (weird, huh?) and roughly 15% is diverted to the oil filter and governor drive via those external oil lines.
