oil pressure on 52 CA
will pratt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote will pratt Quote  Post ReplyReply Direct Link To This Post Topic: oil pressure on 52 CA
    Posted: 30 Nov 2009 at 10:55am
I finally made it up to my farm after a absence of two months.  I started my CA and it started right up but I had no oil pressure at all.  It always has low oil pressure, but in the 3 years I have owned it, it has never had 0 pressure.  The oil level was fine and it ran well.  What could cause it to have no oil pressure?  Can it lose prime to the guage?
Will Pratt
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 11:07am
Probably lost the prime to the pump. Squirt some oil down the main oil pressure feed pipe that runs through the bellhousing. Put the lines back on and fire it up. O.P. should come back... (hopefully)
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 3:17pm
A good condition CA engine has approx 10-15 lbs of oil pressure (somewhere in the middle to upper 3/4 of the gage scale). The pressure may drop just a tad when the engine heats up good and is idling. Steve's suggestion about re-priming the oil pump is good (these tractors can lose the prime if not run for an extended period of time); disconnect the line at the Oil filter (or T to OF) and squirt oil into the line until it is full. Reconnect the line and start it up to see if the oil pressure returns; you may have to try several times to re-prime the pump.
A cause of low, or no oil pressure, can also be a missing tube (or non-seated tube) in the oil filter and a poor quality oil filter. Replace the tube (Tony and Barb can help here) if missing or damaged and install a good filter (I use Fram C130).
Another casue can be missing, or busted up, plugs in the valve rocker shaft. You have to pull the valve cover to check this condition out.
Another cause could be a a plugged up pickup screen in the oil pan. You have to remove the oil pan to check this out.
Another cause could be broken drive pin to the oil pump from the back of the camshaft. You have to split the tractor and pull the camshaft to fix this problem.
Good luck with finding out where the problem lies and fixing it.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 12:10am
Try another Gage. I have had a brand new one out of the box that did not work.
StanInLowerAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 6:25am
My bet is the oil pump has lost its prime.  If there was pressure from the pump on the existing gage when the tractor was last used, nothing else has changed.  I used to have to prime the oil pump on my B but not since I have been starting it up for a short time every few weeks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote will pratt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 10:40am
Thanks for the helpful replies.  When I bought the CA 3 years ago it had been overhauled and runs quite well.  The original oil guage was broken and I replaced it with a new guage from one of the forum vendors.  However, even with the new guage, the correct fram filter, the tube in place inside the filter, and the proper weight  of oil, I have never been able to get the oil pressure to rise above the "N" or lowest setting on the oil guage .  The tractor runs well, doesn't use oil, but the low pressure worries me.  Any suggestions that might help improve this?  Thanks.  Will Pratt
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 2:44pm
Sounds to me like you have bypass in the oil pump and setting the oils seeped back into the pan as  the air got into the pump.  Probly prime the pump and it will be fine until it sets for an extended time.  Probly the fix would be to disassemble the oil pump and check the ball in the stem for pits as well as resurface the pump cover. With the oil pressure you have the vanes and vane springs would more than likely fine.
Added Note::
You will not have oil perssure in the rocker arm shaft. The gage pressure is not bled off thru the rocker arms because of the orifice in the Tee. If you had pressure in the rocker arm shaft and removed the rocker arm cover the oil would squirt out every where instead of just gently running over the rocker arms. With a plug being gone you would not have the rocker arm shaft full to the brim and over flowing to oil the rocker arms. Differnet problem. Something not to be over looked but has nothing to do with oil pressure.
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 2:55pm
It's a long shot but I once had one on a D series tractor (don't remember if it was a 10 or a 14) that had a piece of oil sludge in the line.  It did the same thing.  One day it had pressure, next time I started it it didn't.  Before I tore into the pump I'd pull the guage, bump it over and see if I had flow to the guage and check the guage to make sure it's working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote will pratt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 9:13am
Thanks for all the good suggestions.  I will be back up there over Christmas break and will try some of the things that have been mentioned.
Will Pratt
Post Options Post Options   Thanks (0) Thanks(0)   Quote will pratt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 9:19am
One last question.  If the pump has lost it's prime, does that mean that it is not pumping oil at all to the engine or just to the guage?
Will Pratt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 9:47am
If the pump lost its prime it don't pump anything. It is just full of air, not oil.
