Oil pressure 8550 |
Dale ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: Ontario Points: 375 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Jun 2012 at 4:07pm |
Anyone know what range the oil pressure (in lbs) should be for a 8550?
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5601 |
No I don't, but I do know that it is a GREAT IDEA to run the 8550 or 4W305 with the valve covers off in the shop so you can see 1st hand how much oil is coming out of the rocker arms. This run off oil is the only oil the push rods, adjusting screws, and cam lobs will see. We learned the hard way that oil pressure DOES NOT mean oil volume.
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
both 8550's dad has run about 45lbs all the time. my HD16 which basically has an early version of the engine design is supposed to run 30-50 lbs
