Oil Pan Gaskets
Message Reverse Sort Order
BobDinNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Topic: Oil Pan Gaskets
    Posted: 11 Jun 2010 at 8:26pm
I don't know.  No where have I seen any mention of trimming either the end or the side gasket, but squeezing all that together looks like an invitation to a problem.  Two fellows have successfully taken the trimming approach.  I'm nervous about this because I want this to be the last time this job needs to be done for a long time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 8:12pm
Thanks, Greg.  I'll tackle it tomorrow morning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 8:12pm
So is there a difference in the 17 compared to the WD and 45 pan gaskets? The instructions for them say Do Not trim the gasket. It is to be squeezed in place.
Edited by CTuckerNWIL - 11 Jun 2010 at 8:12pm
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 4:38pm
I trimmed the side gasket over the rim gasket and applied a thin layer of non hardening rtv on the pan side and at the overlap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 2:21pm
What did you trim?  The side gaskets flush with the end gasket?  The end gasket flush with the rim?
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 1:24pm
Just did my D17 I,trimmed them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 12:59pm
How are the ends of the oil pan gaskets (side and end) supposed to mate up?  Are they supposed to be trimmed, tucked in, smashed together, or what?  This is a D17 Series I.
