oil from breather cap
amosfl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amosfl Quote  Post ReplyReply Direct Link To This Post Topic: oil from breather cap
    Posted: 17 Nov 2009 at 5:33pm
I have a 1954 Allis Chalmers B and oil is coming from the breather cap onto the hood. What causes this and what can be done? Thanks Amosfl
Edited by amosfl - 17 Nov 2009 at 5:34pm
amosfl
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2009 at 5:42pm
Likely that you have a compression problem, either worn or stuck piston rings, or valve guides and seals are loose.  Other problems more or less severe might also play into it.  Welcome to the site!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2009 at 6:02pm
Compression test to see if all cylinders are within 20% of each other , leak down test with compressed air into cylinder and listen to where it comes out .. Intake or breather.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2009 at 6:20pm
i am no expert but not a lot of excess oil in them little motors so i would worry there is plug missing and somewhere else is getting less oil than it needs.   Maybe a simple as junk built up in the head passages that drain back to block.  You should pull that cover and have a look they are darn simple little motors.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2009 at 6:33pm
Called blow by. Pressure in the crankcase that vents out where it is designed to vent thru the breather. As the volume of air venting increases more of the oil mist created by moving parts in the crancase clings to the breather cap and changes from mist to drops which gets blown down onto the hood. When the engine is running you can remove the breather cap and place the palm of your hand over the pipe and get an idea of the amount of pressure and volume of air (blow by) being created from the compression passing by the rings into the crankcase.
It will be mostly a ring problem because if the valves are leaking that bad you will have a problem with making it run at all.
I have seen that kind of blow by on what was called a fresh overhaul where the head had been sent out and new rings and bearings had been installed. The blow by was caused from installing standard rings on old pistons in old sleeves without ever checking ring gap. When ask about the ring gap the answer was what is ring gap?
This page was generated in 0.091 seconds.
