Oil For Bevel Gear Box
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Oil For Bevel Gear Box
    Posted: 29 Mar 2018 at 11:56am
I remember seeing a post a while back on someone recommending synthetic oil for the bevel gear boxes.  What grade do you use?  What would be good for the transaxle?  I always just used a trans/hydraulic oil.  Thanks!!
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2018 at 1:16pm
80-90 wt in both.
MARK (LI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MARK (LI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2018 at 2:14pm
I would think a heavy oil also, but my Broadmoor calls for SAE 10W-30 for the trans axle
Would that be because it is a lawn tractor as opposed to a heavier duty Garden Tractor
Anxious to hear replies...as to the original poster of this subject, you really should check the owners' manual
Edited by MARK (LI) - 29 Mar 2018 at 2:34pm
Live and let Live
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 3:22pm
trans-axle varry from 10/30 to 20/50 depending on Mfg .
gear box would be either 000 grease or 90 # gear oil
