Oil filter
 Post Reply Post Reply Page  <123>
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 12:36pm
OK...........Say I want to put the newer filter housings that accept the PH8A filters on my WD and WD-45. Sure would save a few bucks on filter changes!!
As I understand it, the old type filters provide sufficient resistance to keep the oil pressure up and maybe the PH8A pleated paper filters flow too freely?
Is it possible to put some kind of restrictor in the line to achieve adequate oil pressure?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 1:32pm
Where would the savings be? I can buy 3 C159 for the price of 2 PH8A's at Farm and Fleet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 1:52pm
I guess I will say that all of the Fram filters I cut open a few months back were their standard line and not the HP1 Mitch is talking about. They are poorly constructed at best. Cut open a Wix or a Purolator and you WILL see a profound difference.
Nothing against Steve and Mitch, but cut them open and see for yourself. The HP1's may be different, the regular ones are poorly made compared to Wix or Purolator. Champion Labs filters are even slightly better constructed.
The same can be said for aftermarket air filters such as K&N. They may flow more air than a stock paper filter, but they also let alot more dirt through. Probably ok for a race engine, but definitely not a good choice for something you want to live long term.
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 2:11pm
Thats why there is always several different brands of merchandise.We will never all agree 100 % on anything.Fram makes the cheapest filter that I know of on the market.Cheap in price and cheap in quality.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 2:35pm
Sounds just like the Champion plug is no good deal all over again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 4:54pm
Not in this part of the world!!
I can buy 3 FL1A Motocrafts at Wallyworld for the price of 1 C-159 Fram at tractor Supply!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 5:17pm
In my time at a Chrysler dealer I replaced many Champion plugs for misfire concerns under warranty. I have never replaced any AC Delco or Motorcraft plugs under warranty for misfire concerns. The only AC Delco plugs I have replaced were fouled caused by restricted catalyst and not a defect in the plug itself as is common with Champions.
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 8:18pm
I used to race a 69 Z-28 years ago. The guy I got it from ran champion plugs. I switched to motorcraft and got faster times and fewer fowl-outs. I don't know just sayin..... Steve, I operate one of those 55' bucket trucks, and believe when I tell ya that I appreciate the maint. that is done on my truck because when mother-nature is at her worst, we have to be at our best. Nick
Edited by NickT(Ky) - 12 Jun 2011 at 8:31pm
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 8:45pm
On my HD5 it uses a bypass filter which is outside of the engine std lube system but uses a ofice to limit the oil flowing to the filter. So the restriction in the line or backpressure of system is controlled (same as it would be in the AC filter) by this orfice.
 When I changed filter to a PH8 filter I made a filter housing and made my own restrictor to also control the flow and pressure.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 8:49pm
I think a Fram looks the best. Orange right out of the box so ya don't have to paint them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 8:16am
Coke,
What did you use for a restrictor?
Somewhere around my place, I have a Ford remote oil filter housing that I think I could adapt.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 8:29am
Thad, The Fram C-159 filters are white.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 8:33am
Now with that said, come on guys keep it going.
This is fun reading.
I can't find the funnies from the paper yesterday so this will have to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 8:45am
Nick T,
Amen to that brother!!  IBEW Local 327
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 9:04am
Unbelievable !!!!!!!
HOW much of a run can you get for something that was originally a glass jar stuffed with waste cotton ?
wasnt life so much simpler then ?
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 9:36am
A simple question was asked about the part number of a filter. Some chimed in on what they thought may be a better filter for the tractor while others defended their choices. Then the post goes to sparkplugs and cost savings. But the one that amazes me is buying a filter for your tractor because it's the right color, or not. WOW, that will help keep a tractor running for a LONG time!
I joined this site for serious info on old tractors, related implements, and their restoration thinking others were like minded but with replies like these I may be mistaken and see why some find them funny. For me having to read thru all this fluff is tedious and a waste of time just to get to the intent of the original post. Most likely I will be better served sticking to manuals and old tractor magazines.
Edited by mdtractormechanic - 13 Jun 2011 at 9:37am
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 10:06am
Just good discussion,lol!
Toneman1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toneman1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 12:53pm
Now you guys have got me confused as to what filters to buy with all this excellent feedback.  It's kind of like which oil is best to use.
I am getting ready to order filters, all three types (fuel, oil, & hydraulic) for my D17 D Series IV.  Could anybody point me in the right direction?
Thanks,
Tony
Don't worry about the mule going blind, just load the wagon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 1:05pm
Go to nearest Allis Dealer and buy yer filters!!!
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 1:07pm
Bob, that's the funniest reply yet.  My nearest Allis dealer is 2 states away.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 1:39pm
WIX.
CT
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 4:36pm
I've got some KERR canning pint jars and Excess cotton scraps maybe I should make some. Ya think I need a plate or sumtin to keep the cotton in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 4:40pm
Bob, I'm building a time travel machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 4:45pm
mdtractormechanic, We have fun here.
Sometimes too much fun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 4:53pm
mdtractormechanic, You posted: For me having to read thru all this fluff is tedious and a waste of time just to get to the intent of the original post.
The question was answered in the first reply.
You should of stopped there.
Proceed at your own risk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 5:05pm
I use Fram Filters because my mother told me to.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 5:10pm
Here is my thoughts....most of the old tractors out there that haven't recently been torn down, all cleaned out and rebuilt are full of gunk from years of non detergent oil and just plain wear. They most most likely would run just same for many more years if they had no filtration at all and just got an oil change once in in a while. So in my mind the filter debate it mute.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 7:14pm
Boy did I make a fool of my self. The only fram filters i've seen were for cars and trucks from wally world. I use NAPA because they have them in town and gas is to high to make a long trip some other place. Are the napa filters ok now. The ones I've bought in the past looked like the correct one in the pic. Maybe I should just order a dozen and not need to go to town at all.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 7:28pm
I buy them from Agco. Price aint to bad and they have the pretty AC logo on them. It just seems like putting icing on the cake. They look great on a AC tractor. Ryan   BTW, how many other AC brothers will carry this post out another 100 or so?? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 8:08pm
Order them from Steve @ B&B. He usually has en for a good price and if you buy several they are even better priced.
