Oil Filter Bracket
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Topic: Oil Filter Bracket
    Posted: 23 Sep 2010 at 12:56pm
I'm getting ready to paint my B and want to take off the oil filter and the bracket that it's attached to but don't want to get a bath of oil.  Will there be a surprise when I take it off?  Not looking for a clean up job on the floor and side of engine. I feel I could do a better job of painting by taking it off.
Thanks for all the help on my other questions as well.
I have trouble finiding the posts after a few days go by.  Is there a secret to finding them?
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 1:20pm
Fred, I'm not sure about the surprise portion of your question.  But I know the oil filter base can be a common spot for leaks on the Bs and Cs due to issues with the base warping from overtightening, etc.  So if you don't already have a leak there, you may consider leaving it in place while you paint.  HTH
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 2:16pm
If you do have a leak there just take it off (should be no surprise, maybe a few drips) and run a file carefully over the mating surface to bring it back true. Usually gets warped when someone over tightens it after a leak develops.
Wink
I am a Russian Bot
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 4:38pm
I agree.  Remove the filter. The filter bracket has a drain hole into the block.  If the drain is plugged you may have a small amount of oil in the bracket.
Bob, North Carolina
1949 B
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 12:07pm
The filter mount is pot metal, and not AC's best design. I took it off, cleaned out the recess, ran a mill file over the surface, cut a thin steel plate that matches the face of the mount, filled the recess with JB Weld, and bolted the plate on the bracket to dry. I hate oil leaks, and for two hours of work and very little money you end up with a GREAT gasket surface.
Edited by GBACBFan - 24 Sep 2010 at 12:08pm
are genuine." - Mark Twain
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 3:34pm
GBACBFan, I'm with you - oil leaks are a real annoyance. I've done a similar repair on one of my tractors with good results. I also ran into a similar situation with my WC - the engine surface to which the side plate bolts was anything but smooth, and mine leaked persistently. I filled several valleys with JB Weld and then bolted the plate back on - end of leak.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 3:50pm
Good idea Larry, I think I might try that on the CA when I get around to an OH. The CA block isn't machined flat so it has always been a problem.
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 6:40pm
I like the fix with the JB Weld and the pictures were great.  JB Weld is good stuff!  I think I will give it a try.   Hope I get as good results as you did.  I don't think mine is leaking but I didn't get to know the tractor real well before I got very itimate with it and disassembled it.
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 6:45pm
GBACBFan, If I read it right the metal stays with the oil filter bracket and is adhered by the JB Weld and the metal is your new gasket surface.   Is that correct?
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 6:50pm
maybe I need to make(more) plate and gasket sets ?
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 7:05pm
That is absolutely correct, Fred. This is a fun little rainy day project, for not a lot of money. The first one I did (above) had a thin, hand cut steel plate, and the later ones were with a thin aluminum machine cut plate that Bigfish made for me.
With the thin aluminum I bolted a small steel plate on the face as it dried so the aluminum didn't distort, but they work GREAT. A few strokes over the new face with a mill file to make sure it's flush, around the edges to blend the plate in with the housing, and you have a nice  gasket surface. Any questions, PM me your phone #, and I'll call you.
Edited by GBACBFan - 29 Sep 2010 at 7:06pm
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2010 at 6:32am
Well today it's raining so I started last night so I guess I'll finish it today.  Maybe I'll go look for a piece of aluminum.  The outside of the bracket where the bolts go I need to address because they show signs of over tightening.... more JB Weld.  I'll let you know how I make out.
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 12:37pm
I successfully made the plate out of aluminum and attached it with JB Weld.  It looks great and should work fine.  Have not tested since I am in ther process of painting.
Thanks for all your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 8:02pm
When we talked, your idea of cutting a piece out of aluminum angle iron was a good one. Post a pic when you get a chance.
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 9:55pm
how thick of steel did you use to make the plate. looks pretty thin in the picture,
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 10:30pm
The one in the pic was 1/16" mild steel, if I recall. If you look in the bolt holes it gives a better idea of the thickness. The outer edge looks thin because I shaped it flush with the filter housing. I also made one of pretty thin machine cut aluminum that also worked well. It would be hard to cut a real thin aluminum plate with an angle grinder without distorting it.
For hand cutting with an angle grinder, I think Fred may be on to something using aluminum angle iron. Easier to cut than mild steel, and thick enough to stay flat while cutting with the grinder. I hope he posts a pic.
This page was generated in 0.077 seconds.
