Oil Fill Tube 56 CA
Mike(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(GA) Quote  Post ReplyReply Direct Link To This Post Topic: Oil Fill Tube 56 CA
    Posted: 11 Mar 2010 at 2:05pm
The fill tube on the valve cover on my 56 CA is loose.  How are they held on?  I have not removed the valve cover to see what the problem is yet.
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 2:39pm
I've recently had mine off and it appears to be pressed and/or welded. Mine is very solid.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 3:18pm
I took mine off last fall and welded it inside. it looks like it was pressed in but mine got loose enoght to leak. its been great since welding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 6:10pm
Thank you for responding.  I will have mine welded.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 6:45pm
I have had a couple loose. They are just stamped in. I pressed them in place square and spot brazed them in place in four places on the inside. If you can't get them tight I would brazed them all the way around to keep them from seeping oil.
This page was generated in 0.058 seconds.
