Oil Dipstick Darkening
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Topic: Oil Dipstick Darkening
    Posted: 28 Jun 2015 at 8:59pm
Call it old age perhaps but I'm having some trouble seeing oil levels on some dipsticks.
Shiny steel ones work ok with diesel engine oil as it blackens, but transmission oil on shiny ones not so good, particularly the transmission one in a FA 10 dozer
So can I use gun blue to darken these dipsticks without issues? The type I have uses selenium oxide to do the blueing.
TIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 4:51am
I run the dipstick up against a fine grinding wheel side, so it makes horizontal scratches on the ds.  much easier to read...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 5:39am
I've done some reading and apparently there is a trace of selenium in diesel - and I presume lube oil. So I presume no extra nasties.
So I tried the process on the diesel tank dipstick. Using Birchwood Casey product. I put one coat on and aged overnight. Sure is easier to read and we'll see for how long.
